I love my Menzerna IP and FPII and it's getting close to order some more, I really want to try Menzerna CeramiClear PO106FF Polish, my question is can I substitute it for the FPII, or do I use it after FPII? Do I need to order all 3 or can I just order 2 of the products
Thanks Bryan , Have you ever used the ceramiclear before? I remember reading somewhere, that they said ceramiclear is like FPII on steroids, suppose to be really good, Thanks again,
Mark, I have used it quite a bit. It is my go to for that perfect finish. My favorite setup for this polish is a rotary w/ a Green excel detail P2 pad.
As a follow up, the PO106FF is still less abrasive than the IP, correct?
That is correct. It has more bite then the FPII, especially when used with a rotary.
I have found on corvette clear to get a perfect or near perfect finish you need to use 106ff with a rotary. It will still look very good with a PC, but you might not be able to get out every last bit of leftover defect when using the PC.
On softer clear say like a black on a acura, a PC and 106ff will clean up very well.
