Car Care Discussion Car Detailing Info, Wax, Wheel Polish, Interior Cleaning Tips for the Corvette
engine cleaning question
Old Apr 8, 2007 | 04:29 PM
nuvetteowner's Avatar
nuvetteowner
Default engine cleaning question
I park in a dusty environment , and never cleaned under the hood since I got the car july last year.
It is dirty in the engine bay,but I am a little worried I might short something ,or get water on the air filter.
Can some of my vette brothers here give me some cleanig advice,and what product to use? Thanx.
Old Apr 8, 2007 | 04:32 PM
Sven's Avatar
Sven
St. Jude Donor '08-'09
Check out these threads in General Corvette/Car Care Products ...
http://forums.corvetteforum.com/sear...archid=4714428
Old Apr 8, 2007 | 04:40 PM
nuvetteowner
Thread won't open ,but I will try to find the section. Thanx.
Old Apr 8, 2007 | 05:01 PM
User 020720's Avatar
User 020720
Here's a pretty decent instructional video. Hope it helps.
http://www.adamspolishes.com/t-video...ing_motor.aspx
Old Apr 8, 2007 | 05:05 PM
C6Brian's Avatar
C6Brian
I just went to the local pay and spray wash place. What I did was cover the alternator and battery with rags, then I got the sprayer on the rinse setting NOT pulling the trigger so it was more like a highpowered mist and I hit the spots that were dirty on mine. I dont advise using the trigger to get the fast spray or doing it for a long time. Most detail shops use steam to wash the engine bays because you are not spraying water on the motor, but my way worked good. I then rushed home and dried as much of the engine compartment as I could and then I got out the armorall wipes and hit as much as I could. Mine sparkles now and it still runs fine. Give it a try, just remember to avoid/cover the battery, alternator and fuse box under the hood and use LOW pressure spray or steam if possible. One of my local places that closed this winter actually had a setting for engine cleaning/degreasing. You may get lucky, but they are hard to find at those quarter wash places... Goodluck.
Old Apr 8, 2007 | 06:03 PM
6 speed Sid's Avatar
6 speed Sid
I never spray anything under thge hood. If it gets dirty I wipe it off with cleaner and rags.
Old Apr 8, 2007 | 06:38 PM
talon90's Avatar
talon90
Cruise-In 11 Veteran
NCM Ambassador
St. Jude Donor '05-'06-'07-'10
The LSx generation of engines are not fond of high pressure water spray or frequent water intrusion. The LS1 actually has a knock sensor TSB brought about by frequent water intrusion corroding the rear knock sensor. If you have a lot of dust to start with try using a leaf blower to take the bulk dust off then warm the engine up. Mist the bay down (spray bottle) with a 50/50 diluted solution of simple green and water. Let it sit for a few minutes. Take a clean rag and wipe it down. Spray a little more on hard to clean areas. Next I like to take some of the armor all cleaning wipes and just go over the plastic parts. Last, I take an armor all wipe and go over all the plastic parts again. The car will look good as new. It will be easier to keep clean if you keep on top of it, and you will never need to worry about sparying water in there. I just wipe everything down every couply of washes. It only takes a few extra minutes but keeps it looking great.
Paul
Old Apr 8, 2007 | 06:40 PM
Sven's Avatar
Sven
Sorry ... I checked it again after posting ...
I used "engine cleaning" as search terms; don't know specifically your underhood condition and what you want to achieve ... but there were a number of good threads on some very specific aspects.
Old Apr 8, 2007 | 06:50 PM
A pretty fast Vette's Avatar
A pretty fast Vette
Paul
REPLY: I think Pauls way is a very sensible way to do it ; dont dump lots of water in the engine bay...use a spray bottle of Simple Green and Water and use a long narrow nylon brush to agitate extra dirty areas.
Old Apr 8, 2007 | 07:32 PM
twfreightman's Avatar
twfreightman
I have used manual car washes for many years to wash engines with no problems. HOWEVER..... I would not do it on the Vette. Don't ask me why. It just gives me the ******* to think about it. The main thing is to NOT let it get real cruddy to start with. I use simple green to take off grease and armor all to make black things shine. I use Zaino spray detailer on the painted fuel rail covers. I use soft artist paint brushes to sweep away sand and dirt from hard to reach places, and I use tongue depressers/ popsicle sticks to wrap towels around to wipe hard to reach places.
Old Apr 9, 2007 | 05:10 AM
TOGWT's Avatar
TOGWT
From: Ponte Vedra Beach / London State: Dazed and confused
http://forums.corvetteforum.com/show...+bay+detailing
Old Apr 9, 2007 | 12:51 PM
talon90's Avatar
talon90
NCM Ambassador
Bad link?
Old Apr 9, 2007 | 07:02 PM
nuvetteowner
Thanx for the good advice here
Old Apr 11, 2007 | 08:18 PM
2005ArcticWhite's Avatar
2005ArcticWhite
St. Jude Donor '05 thru '11,'18,'20,'21,'24,'25, '26
To engine cleaning question
