Car Care Discussion Car Detailing Info, Wax, Wheel Polish, Interior Cleaning Tips for the Corvette
Paint thickness meter
Old May 9, 2007 | 01:11 AM
uknowwho53's Avatar
uknowwho53
8th Gear
Default Paint thickness meter
Anyone have any brand/model suggestions?
Old May 9, 2007 | 05:27 AM
TOGWT's Avatar
TOGWT
From: Ponte Vedra Beach / London State: Dazed and confused
Paint Thickness Gauge:
An electronic paint thickness gauge can be an invaluable tool, before buffing it’s always a good idea to check the paint film thickness to see how much of the paint film thickness is available, check periodically during the process and on completion to see how much was removed. Take measurements with a paint and coating thickness gauge (Check-Line Model DEF-900) All the major car manufacturers specify that measurements should be taken before, during and after these steps. This is primarily because removal of too much clear coat can cause paint failure over time due to the fact that UVR absorption is the job of the clear coat. If an insufficient thickness of clear remains after polishing the colour coat won't be protected from UV radiation.
For this reason, it’s also recommended that paint be measured when buffing since you can’t see how much paint is being removed during the buffing process. If too much clear is removed, either on the original OEM finish or the refinished areas (colour coat 0.3–0.5 and total paint 1.8MIL thickness min) a warranty issue may develop down the road it’s interesting to note that painters must now demonstrate proficiency with an electronic paint thickness gauge in order to become certified to perform refinish warranty work for General Motors Corp. (GM) vehicles.
*Note this is a model I researched last year, you may want to 'goggle' for updates
Old May 9, 2007 | 10:27 PM
bugman's Avatar
bugman
side note - don't those gauges require a metal surface?
so that if you have a plastic car (corvette) they won't work? Just a thought...
Old May 9, 2007 | 11:38 PM
gmblack3's Avatar
gmblack3
I believe they make models that will work on a vette but they are very expensive.
To Paint thickness meter
