Car Care Discussion Car Detailing Info, Wax, Wheel Polish, Interior Cleaning Tips for the Corvette
What removes....
Old Oct 20, 2001 | 07:02 PM
MDT's Avatar
MDT
Default What removes....
What removes 303 Aerospace Protectant from window glass?
I just used the product for the first time and was pleased with the results, but hereafter I'll spray it on the applicator and then apply. :yesnod:
If someone knows what will take it off the glass, then I can skip the series of experiments to find out. :D
Thanks in advance. :)
Mark
Old Oct 20, 2001 | 08:21 PM
Calabra's Avatar
Calabra
Default Re: What removes.... (MDT)
I would Try Stoner's Invisible Glass or Sprayway glass cleaner first. Using either of these to remove 303 would be experimental for me since I have not tried it.
If that fails Zaino Z12 glass polish will likely remove it. Again experimental for me, but Z12 seems to remove stuff on glass (like nasty water spots) when everything else I try is unable to.
Old Oct 20, 2001 | 08:46 PM
Andy1983's Avatar
Andy1983
Default Re: What removes.... (Calabra)
It is OK.
303 is really strong... your struggle to remove it seems like a good thing. :D
I have always used a towel to apply it with (spray it on towel, then wipe). But instead of buying something, just use water and scrub it hard and alot with a towel. If that doesn't work, use your window cleaner. If you have to buy a polish to remove it.... then something you are doing is not right.
You should already be using sprayway or stoner's already, and if you aren't... you might as well buy some. :)
Andy
Old Oct 20, 2001 | 09:06 PM
MDT's Avatar
MDT
I sprayed some 303 on the bathroom mirror and tried the following, listed in order of apparent effectiveness:
1. alcohol (isopropal)
2. Stoners (almost as good as the alky) Yep, Andy....already use Stoners.
3. Z-7 and water solution (probably a couple of scrubbings would do it)
4. plain water (not much happening here)
5. dry towel (nah)
I'll probably just use the Stoners for convenience.
Calabra.....good call. :)
Thanks guys.
Mark
To What removes....
