Compounding question - test area results
I followed the procedure in the book: 2ft square area, apply compounding polish to surface in two 8in strips, mist compounding pad, select 3.5-4 speed, polish in figure 8's on both planes with very light pressure and until polish starts to dry, 50/50 alcohol mix, and wipe with microfiber towel.
I can definitely see an immediate improvement in gloss after two applications. I have less water spots, car-wash hairline scratches diminished, but I have some questions before I continue.
The surface still had some deeper clearcoat scratches in it, along with some tough water spots. In addition I had some swirl marks from the 2nd compounding step. (I polished a little bit longer this time since I thought the first time wasn't dry enough.) I'm curious what recommendations I can try on the next step? The swirl marks were from the pad, so did I get the surface too hot? So next time I should stop earlier? How many compounding steps would be "enough"? I'm thinking I could get by with at least 2 more since the vette clearcoat is tough, but someone please re-assure me
This is the first time the car has ever been compounded.I can't wait to do the rest of the car now that I see how much deeper the clearcoat looks after getting rid of the haze and hairline scratches!
I'm using Menernza intensive polish, a porter cable DA, a 5" flexible backing plate, and an "orange" 6.5" pad from proper auto care.
When I just went into the garage to double-check what equipment I was using, the test spot is drastically glossier than the rest of the car. The contrast was much more profound than I originally thought. My paint really needed this!
I think you'll find much better results if you raise your speed to 5.5 or 6. If you have any deep scratching, don't be surprised if it takes 4 or 5 passes to really remove those scratches. You can spend two hours just to get a VEtte hood or trunk done (I have).
You should not see any hazing unless you do one of two things:
- you quit on the polish too early - before it has a chance to really break down fully.
- you polish long after the polish has dried - polishing with a dry pad.
My advice : keep doing what you're doing. Work only on that small test area so you can continue to compare it with the parts you have NOT polished. POlish at speed 5.5 - 6, and turn off the machine and re-inspect when the polish flashes to clear - not before and not after.
Sounds like you're already on the right track
PC 7424 review/long
This is what I did several months ago. It's a lot of work with a PC on a vette, but well worth it for us guys that do not have/know how to use a rotary.
I just did a lightning quick coat of Z5P last night followed by ZCS, and my car looks fantastic.
Unless you drop the PC on your car, you should be ok.
Good luck.
Apply a little pressure to the head of the PC (not so much that it stops rotating, but enough to slow the head down a little). The PC is not a rotary and should not be used as such.
I'm going to run out of Mernez Intensive Polish before I get finished with the car, so I need to order some more today. Should I order some that cuts more than what I have?
Also, can anything be done about the other remaining water stains? I'm a perfectionist and wanted the paint to be perfect, but as it stands now it's a little bit less than perfect.
You may want to try SIP if ordering more compound. I also like 3M 06062 or 05093 for a more aggressive polish. For finishing I always use ZPC or PO106ff.
You think you have gloss using the orange pad and Menz IP, try following up with a white pad and the menz PO106FF, I use to love the Menz FP, but the PO106FF really gives it gloss, I very rarely use the FP anymore
I'm definitely going to order super intensive polish! Thanks for the tip.
here are a few pics doing it this way
The whole car was just about this bad.....
I can't just substitute the IP with PowerGloss and go straight to FP? If I went with PowerGloss, I'd still have to use IP then FP?
I just went to the garage and those water spots are worse than I thought. If I had to do at 10+ steps of JUST CUTTING all over the car I think I'd go crazy!
