Cleaning windows
Use dedicated Lint-Free Surgical Towels, they have a tight cotton herringbone weave that is ideal for hard surfaces like glass (http://towelsbydoctorjoe.com/5.htm:) Fold both towels’ (one for washing, one for drying) in half and then half again Mist the glass surface with 1:1 ratio of distilled white vinegar and water in a spray bottle. As with all chemicals they must be allowed a certain amount of time to work (dwell) so leave area to soak for a few minutes and then start on the next glass surface, agitate the first area with the towel, dry the glass with the second towel by agitating in the opposite direction than that used in the cleaning, and repeat for second glass surface and etc. For each section of glass use a clean side of the folded towel
Always wash Lint-Free Surgical Towels separately and do not use fabric softeners but add a teaspoon per towel distilled white vinegar in place of a softener, the vinegar doesn't coat the fibres but instead works to eliminate detergent residue and the acid counteracts any alkaline minerals in the water supply. Vinegar (Acetic acid, pH=2) works well in the rinse cycle to make your towels softer. Detergent is an alkaline (pH=12, the opposite of acidic on the pH scale).
Best advice I've read on glass cleaning in here. Thanks.
