Car Care Discussion Car Detailing Info, Wax, Wheel Polish, Interior Cleaning Tips for the Corvette
Battery Booster
Old Aug 9, 2007 | 08:18 AM
bugn's Avatar
bugn
Default Battery Booster
I'd like to purchase a battery booster. I've never used one of these to jump start. Is it used much the same way as jump start cables?
Thanks.
Old Aug 9, 2007 | 08:24 AM
EVIL_C5's Avatar
EVIL_C5
Uber Waxer
Cruise-In 8-9-10-11 Veteran
CI 9, 10 & 11 Car Show Winner
St. Jude Donor '08-'10
yes, as long as the battery isnt too low to start with. I have a little black and decker one that I use in the winter time if i forget to go start the car for a few weeks.
Old Aug 9, 2007 | 08:36 AM
bugn's Avatar
bugn
Thanks. Appreciate it.
Old Aug 9, 2007 | 01:12 PM
00C Just for Fun's Avatar
00C Just for Fun
Default Portable battery jumper
I use one as back up for my boat that I trailer to the lake. They work well. I loaned it to somebody once who got 15-20 minutes of hard cranking on it without completely draining the jumper's battery.
Old Aug 9, 2007 | 01:48 PM
Z06-JIM's Avatar
Z06-JIM
Cruise-In VII Veteran
I just bought one last week but haven't used it yet.
Here's the link where I ordered it from, supposed to be a good one.
http://www.tooltopia.com/index.asp?P...OD&ProdID=8901
Old Aug 9, 2007 | 02:57 PM
steve8's Avatar
steve8
You also may want to consider a good trickle charger that does not overcharge a battery. They are pretty reasonable.
Old Aug 9, 2007 | 06:06 PM
bugman's Avatar
bugman
this is the one I have. Given the Vette's propensity to DBS, I don't leave home without it.
This is a nice unit - around $120. Will start the Vette, inflate tires, has emergency light. You can even plug in A/C appliances to it -- kind of cool to plug in a TV set during a power outage. Also nice and flat so it sits nicely in the trunk compartment of the Vette
If you've had any troubles with DBS, I think you should also spend the money to have an Optima yellow top - it will let you drain the battery about 1000 times before it loses it's ability to hold a charge. A must-have.
oh - just found my receipt - I actually got that unit for $87.49 at Tyler Tool - so you may want to look there first.
To Battery Booster
