Car Care Discussion Car Detailing Info, Wax, Wheel Polish, Interior Cleaning Tips for the Corvette
Clear ?
Old Sep 3, 2007 | 10:17 AM
steve8's Avatar
steve8
Default Clear ?
I know how hard the clear is on our C5's, but how do you determine that on other makes?
I want to polish my sons 05 Wrangler and was wondering. Is the typical advice just start lighter with the pads/polish and go from there?
I have used IP/orange pads on the vette with great results, just don't want to do harm.
Thanks.
Old Sep 3, 2007 | 07:39 PM
steve8's Avatar
steve8
ttt.
Everyone away for the holiday?
Old Sep 3, 2007 | 09:54 PM
Ralphyboy's Avatar
Ralphyboy
St. Jude Donor '08-'09
I did my son's black Honda Prelude with Menzerna FP and a white pad as a test.I ended up with the orange pads with my PC because the finish was so bad, and weathered. ALWAYS start with a LIGHTER pad and polish in an area that will not be too noticeable. You can always go to a more aggressive grit and pad, but once you have screwed something up, it's much harder to fix.
Old Sep 3, 2007 | 11:52 PM
bugman's Avatar
bugman
yes, with each new make, model, and year of auto, it's a good idea to start low and go slow.
That's part of the reason for always beginning with a "2' X 2' test area ". it is to make sure that you only work on a small area first, determine the formula of machine, pad, polish, arm speed, pressure -- that is correct for that particular auto.
Once you've done your test area to perfection, write down everything you did, and just repeat it on the rest of the car.
If you have a few types of cars that you've had extensive experience with, then of course you know what the clear is like, and you can skip some steps and perhaps jump right in with a more aggressive approach. But always good advice to take your time and work your way up in aggressiveness. I've sure gotten into some problems in the past whevenver I've tried to pollish "in a hurry".
To Clear ?
