Car Care Discussion Car Detailing Info, Wax, Wheel Polish, Interior Cleaning Tips for the Corvette
Help
Old Sep 3, 2007 | 03:41 PM
Harley2Vette's Avatar
Harley2Vette
Default Help
Water spots. Tons of them .Stayed at a motel while traveling. Hotels sprinkler system gave the kind of bath I didn't want. Water spots cover entire front half and windshield. Some of windshield ones came out but not good enough for me. HELP Tom
Old Sep 3, 2007 | 04:08 PM
TOGWT's Avatar
TOGWT
From: Ponte Vedra Beach / London State: Dazed and confused
Use the least abrasive product first-
1. Use a paint surface cleaner (Z-PC Fusion Dual Action Paint Cleaner)
2. Try to dissolve the alkaline-based, surface/etched mineral water deposits try one or more of the following;
a) Use a 2:1 or stronger solution of distilled water/distilled white vinegar (Acetic acid)
b) Try a 2:1 solution of distilled water/Isopropyl Alcohol (adjust ratio as required)
c) Or equal parts distilled water/distilled white vinegar/Isopropyl alcohol.
3. Clean the effected surface with Klasse All-In-One or Zaino Z-PC Fusion Dual Action Paint Cleaner
4. Use detailing clay to remove any `hard' surface granules
5. Use a machine polish (Optimum Polish, Optimum Compound) and a cutting (LC White, Orange or Yellow) foam pad (speed # 4- 5.0) to level the surface
6. For Ceramiclear or other hard clear coats substitute Menzerna for machine polish;
Super Intensive Polish / Nano Polish (105FF) or Final Finish Polish (106FA)Use the least aggressive polish/foam pad first, if this doesn’t remove the problem step-up to a more aggressive polish / foam pad set-up
7. Wet-sand with 2000, 2500 or 3000 grit finishing paper
Old Sep 3, 2007 | 04:48 PM
mitch1959's Avatar
mitch1959
I had some on my dd and a quick spray with detailer and a clay bar spots gone.
To Help
