Car Care Discussion Car Detailing Info, Wax, Wheel Polish, Interior Cleaning Tips for the Corvette
Quick question regarding polish???
Old Sep 23, 2007 | 12:50 PM
Luv My Vette's Avatar
Luv My Vette
Default Quick question regarding polish???
I am going to clay my car today and wondering about the importance of polish. I will Wash, clay, polish , wax... Is the polish necessary???
Old Sep 23, 2007 | 01:43 PM
steve8's Avatar
steve8
I would certainly be prepared to polish after clay.
Whether it's absolutely necessary is your call.
My vote would be for a polish though.
Old Sep 23, 2007 | 06:21 PM
jeremyttt's Avatar
jeremyttt
Well to add on to this question how often should you polish your car? From my understanding polish does remove a small amount of the clear coat right??
Old Sep 23, 2007 | 08:54 PM
Comfortably Numb's Avatar
Comfortably Numb
After you clay you should put something on the finish (wax and or polish). If you are applying polish to rid yourself of swirls then I would say yes go ahead with the polish. If all you are looking for is a shine and paint protection there is no need to polish and wax. I would just wax.
Old Sep 23, 2007 | 08:56 PM
Roughrider's Avatar
Roughrider
What polishes and glazes do...and all polishes and glazes have abrasives, no matter how fine those abrasives...is put microscopic scratches in the paint. Those scratches are what refracts light and gives the finish that "sparkle". Many showcars never get wax after being polished as that can sometimes reduce the "sparkle". The wax is a protective coat from the elements. If the car is a garage queen and never sees the elements, it doesn't really need wax.
Don't recoil in horror over the idea of putting micro-scratches in your expensive paint. How do you think the custom paint shop got any orange-peel out of the finish? They wet sand it and what is sandpaper but an abrasive, regardless of how fine a grit it is.
You have to determine the condition of your paint and decide how abrasive a polish or glaze you need. There's nothing wrong with going right to a wax after claying. You will get better results by using the appropriate grade polish before the wax. Different manufacturers have "systems" or matched car care products that are blended to work best together. I would suggest you stick with one manufacturer's products from start to finish on your car.
Old Sep 24, 2007 | 12:03 AM
bugman's Avatar
bugman
of course there is no requirement to polish (by which I mean 'use an abrasive product') after clay, but it is just a good habit.
claybars often leave some mild marring that you'll correct with your polishing step. Even if there is no visible marring, it's just nice to use a polish as a final cleaning step, a final "smoothening" step for your paint before putting your sealant on.
once the first layer of sealant is in place, you've pretty much committed yourself - so make the paint as perfect as possible before that step.
Old Sep 24, 2007 | 04:28 AM
TOGWT's Avatar
TOGWT
From: Ponte Vedra Beach / London State: Dazed and confused
A polish is used to (a) remove any surface imperfections (i.e. from using an abrasive product like detailer's clay) and to level a paint surface in order to allow a uniform reflectivity (b) to burnish a paint surface to produce a shine.
Roughrider - wax is used to produce a 'depth' of gloss and to provide a sacrificial surface protection (in my experience as a Concours d’élégance judge 99.9% of vehicles use a wax or a glaze
Some prefer the 'look' of a polymer sealant, I find them a little 'flat' and they tend to produce a silver glow, but then 'looks' are very subjective.
But I will say a polymer provides a far more durable protection than a natural wax could
To Quick question regarding polish???
