Car Care Discussion Car Detailing Info, Wax, Wheel Polish, Interior Cleaning Tips for the Corvette
removing zanio
Old Oct 2, 2007 | 12:03 PM
white top's Avatar
white top
Default removing zanio
What is the easiest way to remove zanio so I can start with a fresh clean surface(nothing on the paint)
Jerry
Old Oct 2, 2007 | 12:22 PM
capevettes's Avatar
capevettes
CF Community Team
Active Streak: 90 Days
2016 C2 of Year
2015 C3 of Year Finalist
A clay bar will remove it. Some say a wash with Dawn but I'm not convinced that will get it all. Why do you feel you need to remove it? If the surface is not smooth due to contaminants I would clay bar it.
Old Oct 2, 2007 | 12:27 PM
white top's Avatar
white top
When you look real closely at the surface there seems to be hundreds of water spots in the Z2,
Old Oct 2, 2007 | 01:04 PM
steve8's Avatar
steve8
Without seeing it, it sounds like you are in need of a claybar AND polishing.
Old Oct 2, 2007 | 06:04 PM
User 020720's Avatar
User 020720
Are you sure the waterspots aren't in the clearcoat?
Got any pics?
Old Oct 2, 2007 | 07:34 PM
agentf1's Avatar
agentf1
St. Jude Donor '10
Clay and Dawn will not remove Zaino. You will need to use either an abrasive polish, alchohol or a wax and grease remover like Prep-Sol.
My guess is the water spots are probably in the clear coat and not just the Zaino. You will probably need an abrasive polish to remove them.
Old Oct 2, 2007 | 07:49 PM
jcurley290's Avatar
jcurley290
With Agentf1 sounds like it is in the clear coat. Follow his advice. Good luck, Let us know how you make out.
Old Oct 3, 2007 | 02:14 AM
bugman's Avatar
bugman
if you see water spots, it's not in the zaino layers.
forget about removing the zaino.
you need a pC7424 and an abrasive polish to remove those spots.
the buffing will remove the zaino, get down to the clearcoat and polish out the spots. Then just reapply Zaino.
Not necessary to try to remove your Zaino
To removing zanio
