Car Care Discussion Car Detailing Info, Wax, Wheel Polish, Interior Cleaning Tips for the Corvette
Emblem removal problem
Old Oct 2, 2007 | 10:18 PM
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
Default Emblem removal problem
I removed my C5s rear deck lid emblem. I wash the area, clayed it, zaino'd it and I can still see where the emblem was. Any suggestions??? My BSMs did not do this to me.
Old Oct 3, 2007 | 08:05 AM
Killrwheels@Autogeek's Avatar
0Killrwheels@Autogeek
Former Vendor
I take it , its the 2000 in the pics above ?? If so, think about this, the emblem was in direct sunlight for 7 years. The paint underneath was protected while the sun's damaging UV rays likely took its toll on the paint. You can try to polish the entire car and try to blend in this area specifically but sometimes its easier to get a new emblem and just reinstall.
Old Oct 3, 2007 | 08:22 AM
screw991le's Avatar
screw991le
The car is covered for 6 months a year and covered most of the time after that.
Also, the BSMs did not leave a mark.
Old Oct 3, 2007 | 09:02 AM
steve8's Avatar
steve8
I assume all the adhesive is gone?
Time for a polishing then.
Old Oct 3, 2007 | 09:29 AM
screw991le's Avatar
screw991le
Yes the glue is gone.
I am new to the polish thing. What grit should I use and what should I use for a finish polish.
Old Oct 3, 2007 | 09:51 AM
steve8's Avatar
steve8
A pc7424 is a great tool to have.
I have used orange pad/MIP, followed by orange/ZPC.
You could always start with the ZPC and see if that is strong enough?
Old Oct 4, 2007 | 12:56 AM
bugman's Avatar
bugman
it's kind of hard to imagine what could have damaged the paint underneath the emblem. Not likely to have clearcoat marring there, unless you used some abrasive process to remove the emblem. Maybe chemical damage from heat or glue that was applied origianally?
without knowledge of what the problem is, I don't think we can take any guess on how to correct it.
really need at least to see some pictures -- can you post up? far away view and then as close-up as possible would help a lot. Also - what process did you use to remove them?
Old Oct 4, 2007 | 08:21 AM
screw991le's Avatar
screw991le
Used dental floss to get it off, then goof off to get the glue off. I will get some pics and post them up.
Old Oct 4, 2007 | 12:05 PM
mrosa65's Avatar
mrosa65
As Killr already mentioned it sounds like UV damage. The BSM's are on the sides of the car where the emblems are on top of the car which would be exposed to more direct (intense) UV damage.
Think about it this way. A person laying out in the sun getting a tan. For one hour they lay on their back with their arms next to them, palms facing down. They roll over onto their stomach for a second hour but they place their arms over their head, also palms down. Their stomach and back don't get burned but their arms and back of their hands do. It's because they exposed them to a longer dose of UV rays.
I've had this problem with a motorcycle before. I removed emblems from the side covers (very little or no UV damage) but when I removed the emblem from the rear fender that was flat facing upwards it was very easily seen.
Old Oct 5, 2007 | 09:33 AM
screw991le's Avatar
screw991le
Thanks for the info.
Old Oct 5, 2007 | 11:14 AM
agentf1's Avatar
agentf1
St. Jude Donor '10
I would try wet sanding the area with 3000 grit and then repolish. This should help the area blend much better.
Old Oct 5, 2007 | 11:47 AM
screw991le's Avatar
screw991le
Polish like Zaino or a special polish?
Old Oct 5, 2007 | 01:36 PM
mrosa65's Avatar
mrosa65
You might want to try Menzerna SIP then Zaino ZPC to finish it before applying your other Zaino products.
Old Oct 5, 2007 | 02:24 PM
steve8's Avatar
steve8
You could always try the ZPC first, and then step up to something like MIP if that doesn't do it.
I would recommend ending with ZPC though.
To Emblem removal problem
