What do you guys use to clean the interior surfaces of the vette ? Im using Zaino Z-9/10 for the seats, but whats good for the plastic stuff ? Theres got to be something better than Armor All out there
armor all the worst.....any of the other big name car companies have better stuff.....no more armor all....
Damp cloth should be sufficient to clean unless there is serious dirt in your car. All I use is Zaino but many here use and recommend 303 Aerospace products, mostly the protectant but also the cleaner. Check their website at 303products.com. Good luck.
I clean the plastic stuff with a Mr. Clean Magic Eraser. It removes dirt like nobody's business for those surfaces. I don't use any liquids such as armor all on the inside, only the clean surface left behind.
I wonder if that is going to dry out your surface and lead to cracking and fading over time.
I made sure to keep the sponge damp. Actually, I'll probably not use it again, the first owner had a bunch of scuffs and dirt but I'm pretty picky on a daily basis and probably won't need it from here on out. I was thinking about getting something decent for a liquid but don't want the greasy look of armor all either.
I just used Mr. Clean Magic Eraser to remove scuff marks on door and the black piece between sill and carpet. Worked great. Bought it at Walmart household dept for 2 bucks. Treated with 303 Aerospace protectant.
Armour All works great on DD, but would never put that stuff in Vette.
