Car Care Discussion Car Detailing Info, Wax, Wheel Polish, Interior Cleaning Tips for the Corvette
De-greaser
Old Nov 19, 2007 | 09:59 PM
05C6400's Avatar
05C6400
Default De-greaser
Does/Has anyone used any kind of de-greaser on the lower half of their car? If there is a de-greaser what is recommended?
Old Nov 19, 2007 | 10:29 PM
PSU 98's Avatar
PSU 98
When you say "lower half", are you referring to painted surfaces? Like the areas that are prone to getting blasted with road tar? If that's the case, try Stoner's Tarminator. However, if you mean the undercarriage and wheel wells, there are a lot of heavy duty cleaners to use. I have a gallon of Meguiar's Super Degreaser on hand for that stuff.
Old Nov 19, 2007 | 11:14 PM
Dan1's Avatar
Dan1
Amazing Roll Off and P21S Total Auto Wash are both safe for paint, tires, wheel wells, engine bays, and several other surfaces. Supposedly, P21s TAW is the citrus degreaser that Paul Dalton uses.
Old Nov 20, 2007 | 10:33 AM
05C6400's Avatar
05C6400
Exactly "When you say "lower half", are you referring to painted surfaces? Like the areas that are prone to getting blasted with road tar? If that's the case, try Stoner's Tarminator. However, if you mean the undercarriage and wheel wells, there are a lot of heavy duty cleaners to use. I have a gallon of Meguiar's Super Degreaser on hand for that stuff. "
I assume you can get these products online .
Thanks for the info!
Old Nov 20, 2007 | 11:13 AM
ZaneO's Avatar
ZaneO
P21s Total Auto Wash would probably be the safest "degreaser" type product to use on paint. Remember that it or any other strong cleaner is going to remove any wax/sealant from the finish as well.
I normally start out with a heavy solution of car wash in a spray bottle. Saturate the affected areas, let dwell for a few minutes, and then proceed with the wash.
Old Nov 22, 2007 | 12:16 PM
Killrwheels@Autogeek's Avatar
0Killrwheels@Autogeek
Former Vendor
P21S Total Wash is my go to APC on paint also. You can also use a product called Amazing Roll-off but I dont find it necessary.
To De-greaser
