Question on multiple waxing
I don't intend this string to get into another "which wax is best" deal....I am just wondering if there is any data to support this.
I'm as compulsive as they get, and I'll be washing and waxing my new 2008 a lot...I'm just wondering if it does anything. I live in AZ, so it goes away pretty fast anyway!
Thank you for your thoughts and experience on this in advance!
Desert Dog
This can be broken down into two catagories
Wax - Carnauba based products
Sealants - Polymer based products
If a product doesn't contain cleaners or abrasives and is designed to bond to itself, then yes, multiple layers will provide an added benefit.
My general rule of thumb when using Carnauba based wax that isn't classified as a "cleaner" wax is to apply two coats to make sure I have uniform coverage.
As for sealants, if they're designed to be layered (I use a product that is) then I will apply multiple coats. I have found through some basic testing that they will last longer this way.
For a vehicle exposed to a more harsh climate such as extreme heat, cold and ice (road salt), a lot of rain, etc... *I* prefer a sealant as they're more durable. For a garage queen you can use either wax or a sealant. You can use wax if you don't mind applying it more often in a harsh climate also. Typically here in Florida I've found my wax based products last about 4-6 weeks when exposed to the summer sun compared to my sealant based products which will last 6+ months.
Also the colored paint below it is still affected by UV rays if you don't use a product to help reduce the amount of UV exposure.
Generally products with a lot of solvents, cleaners or abrasives or carnuaba based products do not layer well. On these types of products I would not go past 2 coats and that is only to ensure full coverage.
My general rule of thumb when using Carnauba based was that isn't classified as a "cleaner" wax is to apply two coats to make sure I have uniform coverage.
I Respectfully disagree.
I have no problems putting on multiple coats. Actually I consider two of each Z5/Z2 to be the minimum if you are starting with a clean slate, ie; after a polishing.
You use such a small amount of product, and when applied correctly it is so easy to use.
Now if it's just a quick maintenance coat, I could see doing one coat followed by ZCS and Z8, but that's different.
waxes and sealents are only the final top layer protectant.
Glazes are pure polishes that are non-abrasive.
Polishes (which fall into 2 categories), are Chemical or Abrasive (maybe even both).
Compounds are use when fine polishing isn't enough to remove the defects.
Always start with least abrasive method, and if it doesn't work, go another step towards a medium to heavier cut approach (including what type of pad you will use...). Sometimes using the same product but using a different pad will give you more cut !
compound > polish > glaze > wax or sealent ( you can usually omit glaze)
stay away from DA's if you want to remove swirls and scratches (not fill, hide or round the edges of the scratches) I mean remove!
circular polisher for this ... takes some experience though or you can screw your finish !
Show me a study that says the sky is blue. I bet you cannot find one (seriously).
TH0001 - “Or the fact that I am considered amongst the top detailers in the world that I have polished/waxed/observed more cars that most people see in a lifetime”
That’s quite a claim, “the top detailer in the world” Although I have a great respect for your abilities as a detailer and I have no wish to refute or argue with such a claim, it’s just an observation
Show me a study that says the sky is blue. I bet you cannot find one (seriously). - That's because the sky isn't blue! - http://www.sciencemadesimple.com/sky_blue.html
