I will be doing a customers 67 Camaro soon and want to try Menzerna. (never used it before) The car has some pretty bad swirls that I do not think my Megs #2 is going to cut. The car has been repainted with base/clear and I do not want to wet sand it due to time and money issues. My question is what is the difference between the IP and the SIP. I have seen both take out some very bad swirls and scratches, just not sure which one to use. Thanks
Have a look.
There does have to be a difference, but it sure doesn't look like much?
I have used the IP and liked it, but it definitely looked better after ZPC. The ZPC really brought out the finish.
I have both the IP and SIP and from *MY* experience using both, the SIP finished MUCH nicer then the IP. It may have a little more cutting power but since I didn't use them on a side by side comparison it was hard to tell.
