Car Care Discussion Car Detailing Info, Wax, Wheel Polish, Interior Cleaning Tips for the Corvette
Surface Prep Questions
Old Jan 26, 2008 | 01:25 PM
Montezumas_Viper's Avatar
Montezumas_Viper
Default Surface Prep Questions
Does any suggestions for the pads and material that would be needed to get swirl marks out of my white C5?
I currently have Zaino fusion as a polisher but i'm sure its going to be too weak of a cut. I just bought a 7 in rotory buffer so whatever works with that size will work.
After the surface is prepped I'll be doing...
2 Coats of Z2 + ZFX
2 Coats Z-CS
Old Jan 26, 2008 | 01:50 PM
gmblack3's Avatar
gmblack3
How severe are your defects?
Edge yellow wool with presta 1500 polish for moderate defects.
Edge yellow wool with 3M extra cut compound for deeper defects.
Menzerna SIP is good but IMO a PITA to work with. It was actually made to work on the final assembly line in a controlled environment.
Finishing polishes: You should be able to clean up any "wool mess" with ZPC and a white LC CCS pad.
Menzerna 106ff- very nice but can at times also be a PITA, not as bad as SIP IMO. LC CCS white pad
3M ultra fina- My favorite finishing polish. Get it with the 3M blue 8" foam polishing pad. Never a hologram left on the rotary. Even on soft black clears.
Menzerna FPII- works very nice. LC CCS white pad.
Old Jan 26, 2008 | 01:52 PM
gmblack3's Avatar
gmblack3
If not using ZPC for a finishing polish, then you should do a 50/50 IPA/water, Z6 or just rewash the car to get the proper surface for Zaino to bond to.
Old Jan 26, 2008 | 03:13 PM
agentf1's Avatar
agentf1
St. Jude Donor '10
I have gone right over ZPC with NO problems at all. Maybe a Z6 wipe if there is a lot of polishing dust but ZPC contains no oils so it wil not hinder Zaino bonding.
I have also been able to remove a significant anount of defects with just ZPC and the proper pads on my rotary. For instance if you have a purple foamed wool pad and use it with ZPC at speeds of 900 to 1200 it will remove some pretty significant moderate swirling and then just follow up with a white pad/ZPC and then apply your Zaino.
Old Jan 26, 2008 | 07:02 PM
Killrwheels@Autogeek's Avatar
0Killrwheels@Autogeek
Former Vendor
move to Menzerna polishes, specifically 106FF and you'll be pleased. Works well with Zaino too.
Old Jan 26, 2008 | 10:20 PM
steve8's Avatar
steve8
First of all I would say, listen to these guys.
Second of all and no offense intended, do you know what you are doing with a rotary? ( I don't).
If you do, take their advice.
If you don't, get a PC7424.
To Surface Prep Questions
