Car Care Discussion Car Detailing Info, Wax, Wheel Polish, Interior Cleaning Tips for the Corvette
One last try...
Old Apr 10, 2008 | 04:09 PM
MarkRx's Avatar
MarkRx
Default One last try...
can SOMEONE tell me how to get rid of these on an arctic white 08 coupe. It's been driven 10 times or less. The dealership put these on when it went thru PDI. I have a porter cable and i want to know what product, what pad manufacturer and color, PC speed, and what you would wax/seal it with after you get that mirror finish. This may sound simple, but i've been told everything from a 2000 grit compound with a aggressive cutting pad to a light swirl remover with an almost no cut pad (finishing pad).
If you know what works please chime in. the table in my garage looks like the shelfs from Pep boys, i have a ton of cleaners, polishes, and waxes, lots of microfiber and meg's and buffandshine pads. I've tinkered with some products on my 10 year old faded black CRV and my girlfriends 06 scion with the same light swirl marks as my vette and i can't get anything out. Any help would be great.
Old Apr 10, 2008 | 05:45 PM
Killrwheels@Autogeek's Avatar
0Killrwheels@Autogeek
Former Vendor
start with Menzerna SIP with PC on high speed (6), well after initial spreading of polish so no spitting, and work each area for several minutes until polish flashes. Use a med to aggressive pad. Then move to 106FF and med/light pad (step down) once you have look desired. Usually it can take two applications of SIP to make difference. Slow, with patience ...
Old Apr 10, 2008 | 06:28 PM
agentf1's Avatar
agentf1
St. Jude Donor '10
Give Zaino ZPC a try on a white LC pad with your ROB speed set at 5.5.
Follow up with a few coats of Z5p and it should look 1000 times better. It may require a more aggressive approach if there are any deep swirls but it does not appear so in the pics.
Old Apr 10, 2008 | 07:33 PM
Dave1's Avatar
Dave1
St. Jude Donor '09
It's usually hard to see those on Artic White......
Black is a whole new world so, consider yourself lucky......
With your PC I'd get some Menzerna polish to get the job done. SIP or IP with and LC orange pad on speed 6 will work just fine on your vette clear coat. Work inside small 2x2 foot windows and take your time.
After the paint is corrected, you can use a wax or a sealant, your choice. The key to keeping the finish swirl free will be in your washing habits. Good luck......
steve8's Avatar
steve8
This is the difference between me, and I would guess 95-98% of the people here (novices) and a small handful of the pros. I look at that and think fairly severe, especially for the age.
A rotary in the right hands will take care of that in no time.
With a PC, I like MIP, but I love ZPC.
I would say mip/orange, followed by ZPC/orange, and finish with ZPC/white.
I have not been a fan of the white pad, but I am just finishing my personal "ultimate detail" and I did those three steps.
I now have three coats of Z5P on, and I plan on either a little more, or a few Z2P before the ZCS.
I will post a full write up with pics soon.
Good luck to you.
MarkRx's Avatar
MarkRx
Originally Posted by Killrwheels@Autogeek
start with Menzerna SIP with PC on high speed (6)...
6???? the porter cable sounds and feels like it's going to explode on this setting. right on the PC it says do not exceed 5" pad. only pads out there are 6"
Give Zaino ZPC a try on a white LC pad with your ROB speed set at 5.5...
there is no 5.5! it's either 5 or 6 i'm really trying to take all this is, but can you see how it's so darn confusing? I guess i will start with a mild polish and use the softest pad and work my way up with the pads. if that doesnt cut it (har-har) then i will switch to a more abrasive polish and work my way up thru the pads. sound about right?
Old Apr 10, 2008 | 07:39 PM
Former Vendor
I have run mine at 6 for 5 years without fail. Make sure you installed the washer from the directions before first use. If you are worried on speed, pull the dial back a small bit to around 5.5 on dial. (it wont click in)
All of us have run larger pads on the PC. Some run 7" pads. There are two counterweights available (one suggested for bigger pads) but no real difference. I would start with 106FF and white pad initially , if it doesnt work change polish (SIP) or pad (orange).
Old Apr 10, 2008 | 07:44 PM
Dave1's Avatar
Dave1
St. Jude Donor '09
Originally Posted by MarkRx
1.) 6???? the porter cable sounds and feels like it's going to explode on this setting. right on the PC it says do not exceed 5" pad. only pads out there are 6"
2.) there is no 5.5! it's either 5 or 6 i'm really trying to take all this is, but can you see how it's so darn confusing? I guess i will start with a mild polish and use the softest pad and work my way up with the pads. if that doesnt cut it (har-har) then i will switch to a more abrasive polish and work my way up thru the pads. sound about right?
1.) The only setting I use after spreading the product around on a PC is speed 6. The clear coat on your vette is rock hard and to be honest with you, a PC is a mild machine for the job. Your not going to burn your paint with a PC. Period. As far as the pads, 4",5" or 6.5" will work fine, the backing plate has a lot to do with the pad selection. The pad needs to be larger than the backing plate......No biggie here.....
2.) Again, no big deal . Don't freak out about 5.5. Use 6 and forget about it...... Once you get the combo's down, pad/product, it's a lot of fun.....
This isn't rocket science, you can do it....
Old Apr 10, 2008 | 09:46 PM
MarkRx's Avatar
MarkRx
hey guys thanks for the great input, it seems i'm way to cautious with the pad and speed. i'm going to take it up a notch on the daily driver and see what it'll do!
Old Apr 10, 2008 | 10:25 PM
The Detail Dude's Avatar
The Detail Dude
I sent you a PM
Old Apr 10, 2008 | 10:37 PM
TH0001@properautocare.com's Avatar
0TH0001@properautocare.com
Former Vendor
Originally Posted by The Detail Dude
I sent you a PM
Are vendors allowed to solicit privately?
Old Apr 10, 2008 | 10:56 PM
The Detail Dude
I have been working with Mark for about 2 weeks now.
BTW, Mark....let me know when you are by the phone.
Old Apr 11, 2008 | 06:56 AM
mvcrash's Avatar
mvcrash
Yes
Old Apr 11, 2008 | 09:04 PM
gmblack3's Avatar
gmblack3
Is this a pic of your cars paint?
Old Apr 11, 2008 | 09:57 PM
MarkRx's Avatar
MarkRx
negative. it's an example of the swirl marks that the dealer put on my brand new arctic white coupe.
Old Apr 12, 2008 | 06:03 AM
gmblack3's Avatar
gmblack3
I thought it might of been one of your other cars.
Old Apr 12, 2008 | 11:53 AM
MarkRx's Avatar
MarkRx
naah, i dont have that many cars! i made the other thread experimenting with the CR-V as a test mule.
To One last try...
