I think NXT will remove your sealer or glaze if you use it as a topper. This is just from my experience and I could be wrong.
I started using NXT and topping it with carnauba on my daily drivers. So far it looks great and it's been around a month since I detailed the truck. I started to follow up my washes with Pinnacle Spray wax and it gives it a freshly detailed look.
NXT does have a light cleaner in it that will likely remove or haze with the use of a glaze. Just use the NXT and hit it with a good pure carnauba, spray wax, or quick detailer with extra gloss as needed/wanted.
Killr,
The Megs Ultimate QD says its a polymer and does better after 12 hours. I've used that as part of my clean up process after washing to remove water spots, etc (black car in TX dries too fast). My base sealant is DG111....Am I removing that?
no, Megs Quik Detailer is a polymer based spray with very little cleaning ability. It wont harm a cured sealant, but I would refrain from using it for 8 hours after fresh application of sealant. Have you tried Aquawax ?? Its made by Duragloss and works well with your sealant as another choice.
No, I haven't. Do you sell it? Is it available at local places? Thanks for the suggestion.
