I would like to get some more shine out of my factory clear coated 01 wheels. Waxing them just isn't doing it. Can I safely polish them? What are your secrets? Any and all suggestions would be greatly appreciated.
Thanks.....
I've had good luck using the same products on my wheels that I use on my finish.
SIP, ZPC, and Z sealants.
I used my PC where I could.
The pic is not good, but the wheels look great.
you can indeed polish OEM clearcoated wheels, just with the correct polishes. In this case a paint polish (clearcoat is paint) is ok to use. I would however warn that some of the milky appearance is by nature the clearcoat GM uses.
I use hand for sealing the wheels. I do rather like the Powerball Mini for light polishing on uncoated wheels but really comes down to the power of the drill being used.
