Flex vs. Porter-Cable
Then I'm looking at the Vac n' Blo dryers fo keep from scratching the paint after I get it detailed. . . Wow, this detailing can get expensive!
Thanks in advance for the opinions, guys.
i own and use a rotary, pc and flex i reach for the flex for the vette no holograms
If you don't mind taking longer to remove any specific defect, then the PC would be an excellent choice. In my case, I have a surplus of time, and additionally I enjoy working slow, checking my progress every section, and making sure I'm getting my results. I am in no hurry, so the speed benefit of the Flex is of no interest to me.
Also, the PC can easily use 4" pads; whereas it's complicated and more expensive to set a Flex up to do that. I love those 4" pads. I can get into tighter corners and gaps that no bigger pad can do. For example, if you have body side mouldings, a 4" pad will nicely fit the area beneath the molding and above the lower door contour. As well, the 4" pads are more effective on a PC due to the smaller surface area vs. power of the motor. As a matter of fact, I don't even own pads that aren't 4".
Meanwhile, the Flex can power through the work quickly with larger pads; that's great for people with less time, or who do a lot of vehicles, or one vehicle frequently. I've been tempted to move up to it a million times, but in the end... I can't justify it. My PC took a heavily-swirled black Z06 to one of the finest finishes I could ever have imagined. I didn't care that it took a while longer than it could have.
www.autogeek.net
www.autogeek.net
I paid about $40 for my Toro at Lowe's a couple of years ago and it works great.
I own a PC that I'm very happy with, but recently took advantage of one of the Geek's sales to buy myself a Flex. The sale discount coupled with the free shipping because the order was more than $95 all added up to a good deal.
I can't wait for Spring to try it out.
Thanks to everyone for the advice, and thanks to AG for the special deals, probably wouldn't even considered it without them.
The Flex has more power. Watch this video for a comparison.
http://www.youtube.com/watch?v=Yht1uHJLNlQ
9600 orbits from 6000 ....seems like a bit faster and stronger motor also.
(those fat headed ones from Sears and Waxmaster move at about 3000 orbits)
:Like I said, I'm no expert, just wanted to make sure the product is flawless, reading the above post has put a doubt in my mind, that's all.
Not to be a real smart azz, but you bought a Vette. By the same thinking you likely should not because it mass produced and every so often a lemon or bad unit rears its head. Heck I only have 12k miles on mine and 4 targa's replaced !
Seriously though, the rust is likely the culprit of the end user drying wet pads by spinning them which is a common suggestion but presents water to the drive unit. Thats why we sell and suggest a formal unit that does not introduce water to the unit. http://www.autogeek.net/grit-guard-u...ad-washer.html
The teeth being damaged is likely adding pressure to the unit while at an angle thus forcing the backing plate to rub against the teeth and well cut into them a bit. The Flex does not need the pressure exerted when using the PC to correct paint, and thus "could" be the end user. We have not seen any other damage like this to date. It could also be a bad or worn bearing but quite limited to date.
Finally, in a few units we have seen the felt ring move up and touch the backing plate. (it in fact happened to mine on second use, but more than 10 uses sinces has not reappeared). Because the tolerances are quite small and movement with this felt adapter and backing plate can rub causing the burn marks to back of plate. I installed the replacement quickly, lubed as suggested, and never seen any more movement to date. I believe these felt adapters are being better lubed in all future machines based upon comment.
Again in ending, this unit is very much like the mass produced Vette. Every year as certain "bugs" effect a number of cars the manufacturer replaces the issue and makes changes to the line. I can tell you from personal contact, I would much prefer with Flex versus Chevrolet on a repair should it be needed, they are certainly more Lexus in accomidating their clients.
Last edited by vetteship; Feb 7, 2009 at 05:39 PM. Reason: did not finish comments
