Car Care Discussion Car Detailing Info, Wax, Wheel Polish, Interior Cleaning Tips for the Corvette
What did I do wrong?
Old Feb 14, 2009 | 07:07 PM
waddisme's Avatar
waddisme
Default What did I do wrong?
After clay barring, compounding, polishing, glazing and a coat of NXT, I usually finish off with a coat of the Meguiars Liquid Gold Class. However, this time, the Gold Class streaked really bad and it would barely wipe off. Temps were 65 deg today, I shook bottle really well(brand new bottle), I let it dry for over 4 hrs. After I wiped it off, you could almost still see every stroke where I put it on with the yellow Meg pad. Did I put too much on?, not enough?, not even enough?, not let it dry long enough or too much? I went over it with the Meg quick detailer and it seems to have removed most of the streaks. Thoughts?
Old Feb 14, 2009 | 10:03 PM
bldavis11's Avatar
bldavis11
Have you've used the NXT under Meg's Liquid Gold Class before? The NXT might not have dried / cured enough before you put LGC on top.
Old Feb 14, 2009 | 10:31 PM
rbrcs's Avatar
rbrcs
Disabled by request 27 March 2026
I used GC over NXT 2.0 and had no problems. I did let the NXT cure for over 12 hours. The NXT is great, but it seems to me that the GC gives the finish a deeper look (?).
Old Feb 15, 2009 | 01:35 AM
waddisme's Avatar
waddisme
I have used the GC over the NXT before with no issues. I put the NXT on Tuesday.
Old Feb 15, 2009 | 09:20 AM
Killrwheels@Autogeek's Avatar
0Killrwheels@Autogeek
Former Vendor
two issues caught my attention when discussing streaks and reading the process of attack, are the products compatible (layering) and did end user use to much of a product ??
NXT is technically a sealant and should receive 8-12 hours of curing time before any topper. Gold Glass is a wax with cleaners and not the best topper as it is stripping away the NXT in part. I would move to a pure wax like Megs 21 , Megs 16 (discontinued), or something like our Pinnacle and Wolfgang lines.
Also remember with waxes and sealants, its not how much you use but how well you cover the surface. Very light product is all thats needed and often too much product will streak. Environment, like humidity, can also effect this to a degree. A damp towel is usually the easiest way to remove these streaks when a wax was used and then further refining the proper amount to use on next detailing session.
Old Feb 15, 2009 | 11:19 AM
waddisme's Avatar
waddisme
I got the suggestion from the Meguiars forum a couple of years ago. All i have ever used in my whole process is, 3M compound and polish (39002 and 39003), Mothers Glaze, NXT and then the Gold Class. It has worked well in the past and I was able to get locally. However, this time a) even with the new LC orange waffle pads, the compound did not really seem to remove scratches and blemishes like before. Granted, there were a few more from the engine repl, but I thought I would do better than what I did. Maybe I should rethink my process and products. Anyway, I may research that in another thread. I will try the Meg 21 as the GC usually doesn't last longer than 2 weeks. Thanks.
Old Feb 15, 2009 | 11:45 AM
Dave1's Avatar
Dave1
St. Jude Donor '09
If you're looking for a little more correction, look no farther than this product:
It's finishes down fantastic and is top of the line these days.....I don't know what machine you're using but, the new version of 105 can also be used with a PC........
Old Feb 15, 2009 | 02:35 PM
waddisme's Avatar
waddisme
I use the PC. Is this in place of the Mothers Glaze I been using (right before waxing)?
Old Feb 15, 2009 | 06:49 PM
Former Vendor
Mothers Glaze is a pure glaze meant to temporarily fill and hide swirls. It is really designed for those that dont polish. If you use a machine and abrasive polishes then cut out the glaze (the light cleaner in NXT might actually just be removing it) and move to Menzerna SIP and Nano polishes and buffer.
Wash -- Clay -- Compound/Polish --- NXT 2.0 and then #21 as wanted for additional wetness
Old Feb 15, 2009 | 09:58 PM
waddisme's Avatar
waddisme
Got it. Much thanks.
Old Feb 16, 2009 | 12:27 PM
Blackout's Avatar
Blackout
Cruise-In I Veteran
Cruise-In II Veteran
OK....im not a newbie here.....but for the life of me....WHAT IS A PC?....power circular?? i know that ROB is random orbital......
Old Feb 16, 2009 | 12:31 PM
Dave1's Avatar
Dave1
St. Jude Donor '09
Porter Cable's version of a random orbital..........
To What did I do wrong?
