Car Care Discussion Car Detailing Info, Wax, Wheel Polish, Interior Cleaning Tips for the Corvette
Hud
Old Apr 2, 2009 | 07:08 PM
RadarP3C's Avatar
RadarP3C
Default Hud
Sorry if this has been covered. I did a search, but no luck.
1) Can I use glass cleaner to clean the HUD lens?
2) When cleaning and dressing the dash, I stuff a cloth on the HUD to protect it. Is there a better way to protect the HUD lens?
Old Apr 3, 2009 | 12:57 PM
Detailed Image's Avatar
0Detailed Image
Former Vendor
I typically do not use glass cleaners on them, but it also depends on the cleaner. Generally I like to use the Chemical Guys Plastic Cleaner and Protectant on tho screens, plastic gauge covers, etc. It does a great job of cleaning and protecting the surface without leaving a thick residue behind. I also use this product a lot on my lap top, cell phone, ipod, etc.
To prevent product from getting on the HUD I highly recommend just spraying the product directly on the microfiber towel outside of the vehicle. This eliminates all the over spray problems and helps you complete a nice even coverage of product.
Let me know if you have any other questions.
Greg @ Detailed Image
Old Apr 3, 2009 | 03:47 PM
RadarP3C's Avatar
RadarP3C
Thanks, Greg!
With your lens cleaner recommendation, are you saying the HUD lens is not glass but is lexan or plexiglas?
Old Apr 3, 2009 | 04:17 PM
0Detailed Image
Former Vendor
Thanks, Greg!
I don't think I have seen a HUD that uses any traditional glass. I believe it's a form of plastic as you suggested.
Old Apr 3, 2009 | 05:17 PM
James92's Avatar
James92
yep, it's plastic.
Old Apr 3, 2009 | 06:12 PM
JJU's Avatar
JJU
Acct Suspended by request 25 MAY 2026
Cruise-In II Veteran
In case it's not obvious, do not spray anything directly on the HUD.
You only need to use a moist cloth with light pressure to get it clean.
Old Apr 3, 2009 | 06:40 PM
daddoe's Avatar
daddoe
I've been using a window cleaner like Stoners that is safe for plastic tinted windows, thinking it will be safe for the plastic lens.
I spray a little on a microfiber towel and clean the HUD.
Old Apr 3, 2009 | 07:59 PM
RadarP3C's Avatar
RadarP3C
Thanks for the input everyone!
Old Apr 4, 2009 | 08:27 AM
Killrwheels@Autogeek's Avatar
0Killrwheels@Autogeek
Former Vendor
As offered, dont spray directly into the Hud. Spray on towel and buff. I find Stoners Invisible Glass to work well , even Plexus, on a MF WW Glass Towel.
As for getting around the HUD for cleaning. Your method is great. I do find for glass cleaning specifically you need a Glass Master to get the area behind the HUD however.
http://www.autogeek.net/glass-master-pro.html
Old Apr 4, 2009 | 11:20 AM
RadarP3C's Avatar
RadarP3C
Scott, I already have the glass master which I ordered from you over a year ago. Works great! BTW, I just ordered a few items (4/02) and forgot to use "corvetteforum" in the coupon box.
As you and others have mentioned, I use Stoner's for the glass but I haven't used it on the HUD lens.
Old Apr 4, 2009 | 05:21 PM
Former Vendor
Call in with order, and they will repair or provide credit on next order. Always use the couponcode
Old Apr 4, 2009 | 05:36 PM
RadarP3C's Avatar
RadarP3C
Thanks, Scott!
To Hud
