Car Care Discussion Car Detailing Info, Wax, Wheel Polish, Interior Cleaning Tips for the Corvette
Question about Buffer pads / colors
Old Apr 28, 2009 | 09:05 PM
Alaskanpilot's Avatar
Alaskanpilot
St. Jude Donor '08-'09-'10
Default Question about Buffer pads / colors
Hi all,
It's been some time since I've used some of my pads, and as a result I can't recall which is more aggressive than the other:
They are all 4" spot buff pads from Lake County. I have green ones and white ones. I know they are pretty close together in terms of performance. But which is the more aggressive of the two?
Old Apr 28, 2009 | 09:40 PM
Onyasix's Avatar
Onyasix
Originally Posted by Alaskanpilot
Hi all,
The white is more aggressive by one level above the green. Out of the seven pads from Lake Country, yellow being the most aggressive and red being the less. The green white is the third most agressive and the green is the fourth most agressive. Hope that helps.
Old Apr 28, 2009 | 10:17 PM
bluestreak63's Avatar
bluestreak63
Actually green is more aggressive...
http://www.lakecountrymfg.com/padappguide.html
Old Apr 29, 2009 | 12:06 AM
Onyasix's Avatar
Onyasix
I stand corrected. I was going by the chart that was shipped with my pads. It shows yellow, orange, white, green, gray, blue, and last red. I assumed that they were in order of aggression. The chart at your link clears that up. Thank's for the heads up. It's easy to jump to conclusions.
Old Apr 29, 2009 | 06:13 AM
TOGWT's Avatar
TOGWT
From: Ponte Vedra Beach / London State: Dazed and confused
Lake County (LC) colours and abrasive ratings-
Key - (C) Compounding, (H) Heavy, (M) Medium, (L) Light, (F) Finishing (Fi) Finessing
1.Yellow (C) CCS Foam, Compound Cutting
2.Orange (M) CCS Foam, Compound / Polishing
3.Green (L) CCS Foam, Cutting/Polishing
4.White (L) CCS Foam, Polishing
5.Black (F) CCS Foam, Fine Polishing
6.Blue (F) CCS Foam, Finishing
7.Gold (Fi) Concours Foam, Finesse Finishing
Old Apr 29, 2009 | 07:03 AM
steve8's Avatar
steve8
I have not seen this before, thanks.
I have orange, white, and black, and imo that covers everything.
Old Apr 29, 2009 | 09:47 AM
Autogeek.net's Avatar
0Autogeek.net
Former Vendor
That is not correct. The green pads he has are custom made for us and are LESS abrasive than the white. You guys are confusing these with the OTHER green (medium) pads we have, which do fit in the way that scale describes...but the ones he is using are between a white and gray pad.
Old Apr 29, 2009 | 12:34 PM
Alaskanpilot
Great, thanks for the info!
Old Apr 29, 2009 | 02:41 PM
Dave1's Avatar
Dave1
St. Jude Donor '09
Just the 4" versions.......?
Old Apr 29, 2009 | 02:46 PM
0Autogeek.net
Former Vendor
It applies to the 4", 5.5", and 6.5" CCS pads. There are two versions, the coarse/medium cutting green pad, and the green polishing/finishing. Pilot has the latter.
http://www.autogeek.net/lakecountry.html
Old Apr 29, 2009 | 07:56 PM
Onyasix's Avatar
Onyasix
Now I'm really confused. The pads that I ordered with my Flex from AutoGeek came with a SmartPads Polishing Guide pamphlet. On the front cover of that pamphlet it lists seven pads. Are these in order of their abrasiveness?
Old Apr 29, 2009 | 10:10 PM
bluestreak63
Sorry, but LC still says the green is more aggressive in the 4" CCS spot buff pads...
http://www.lakecountrymfg.com/spotbuffpads_ccs.html
So LC ranks them like this (most aggressive to least aggressive):
Yellow, Orange, Green, White, Black, Blue, Red
http://www.autogeek.net/4inch-spot-buffs.html
Autogeek ranks them (most aggressive to least aggressive):
Yellow, Orange, White, Green, Black, Blue, Red
Old Apr 29, 2009 | 10:18 PM
Choreo's Avatar
Choreo
As usual "Going Green" is riddled with controversy!
Old Apr 30, 2009 | 12:07 AM
Alaskanpilot
Well this sucks!! I guess I'll just pick one and run with it! I have to get my car touched up for a show Friday but don't expect to have time to go over it with two different kinds of pads. I know I don't need the orange pads; or the SIP; I'll run with the Nano and the greens and see if that works for me.
Old Apr 30, 2009 | 03:30 AM
Snowwolfe's Avatar
Snowwolfe
Where is the car show at?
Old Apr 30, 2009 | 03:13 PM
0Autogeek.net
Former Vendor
Right, like I said the medium/coarse green pad is more abrasive than a white pad. But the custom green polishing/finishing pad, which isn't listed in those LC links, is between a white and gray.
Old Apr 30, 2009 | 06:01 PM
Alaskanpilot
It's in your neck of the woods! Eagle River! It's at the McDonald Center (kinda next to Fred Meyers). Are you with the Anchorage Corvette Club? We're all meeting at Captain Chuck's (next to Northway mall) and will depart there at 5:30pm Friday as a group. We'll probably hang out at the show for a couple hours. Even if you're not a member, I dont think anyone would mind you coming along anyway as a "prospective" member. I think the venue charges $5 to get in; they did last year.
Any questions, shoot me a PM!
Old Apr 30, 2009 | 10:25 PM
cmonkey713's Avatar
cmonkey713
The gang at Autogeek is very very good at what they do. Duane has helped me many times with questions and problem solving. These guys know their stuff. I have improved my technique and results several time over following their advise. I too have an assortment of pads for various uses. The Autogeek website has a Lake Country chart that specifically identifies all their pads and uses.
To Question about Buffer pads / colors
