Zanio QUESTION.......
After prep (Dawn, clay bar, car wash) and the finish is free of contaminates, start with the Z-PC using the PC and if you have any Z-AIO, you may want to finish the base prep with it.
Next, apply your Z-5 my hand (1/2 oz) with ZFX. Inspect the finish you may want to put a second layer of Z-5 if there are signs of very slight blemishes. I wait about 30 min. between layers of Z-5/Z-2. There should be a slight haze as the Z-5/Z-2 cures. Remember Zaino polishes/sealants are not like most other products, a small amount goes a long way. One mistake that most first time users make is applying toooo much.
Next, start applying the Z-2 (with ZFX), ½ oz per layer by hand. Put on as many layers as you need to achieve that depth and shine that you are looking for (I would put a minimum of two layer of Z-2). Use Z-6 between each layer of Z-5/Z-2. After your final layer of Z-2, finish it off with Z-8.
You do not need to use your PC to remove/buff off Zaino polishes, 100% cotton or heavy nap high quality MF towels will do the trick
P.S. I'm not a fan of Z-CS
Assuming you have selected Z-PC for swirl correction, you might want to consider a wash and clay before hitting it with Z-PC. I would do one application with orange pad and second application with white pad. If you do not need swirl removal then I would suggest starting with Z-AIO as a base or move directly to your Z5 application.
I would suggest applying Z2 AFTER you apply the Z5.
Remember to apply polish(Z-PC or Z-AIO) with machine and protection (Z5, Z2 etc...) by hand.
Here is a sample 2 day marathon....
DAY 1
Wash with Z-7
Clay with Z-18
Wash with Z-7
Z-PC with orange pad (PC7424)
Z-PC with white pad (PC7424)
Wash with Z-7
Z-5 Pro w/ZFX (Hand with 100% cotton towel)
Z-6 (Hand with 100% cotton towel)
DAY 2
Z-6 (Hand with 100% cotton towel) – Want to remove any dust etc.. that settled on car overnight.
Z-2 Pro w/ZFX (Hand with 100% cotton towel)
Z-CS (Hand with 100% cotton towel)
Z-8 ((Hand with 100% cotton towel)
MAINTENANCE (once a week)
Wash with Z-7
Z-8
Z-6 for quick detailing between washes
Hope that helps.
The orange pad is more aggressive and you may need that.
Z5 w/zfx allows you to put 3 coats on in a 24 hr period. You can get 3 coats out of 1 oz. PUT IT ON THIN!
Follow with 2 or 3 Z2.
I would end with ZCS and top that off with Z8.
ZPC via machine, Z5/Z2 by hand, MF towels to remove.
So it's wash, clay, wash, polish, protect.
This is what I did earlier this year with my flex.
http://forums.corvetteforum.com/car-...tail-pics.html
There is no magic time for how long it takes for the Z5/Z2 to dry with or without ZFX. You just have to swipe the finish with a clean finger. If it exposes clean paint, its ready to come off; if it smears it has not yet cured and you'll have to wait a bit longer. Temperature and humidity will all affect the drying time.
I just keep the car clean & covered when not in use.
I use very light coats of Zaino about once per month.
Z2 is all I use and the results are great.
IMHO, the Zaino "chemists" are a little overboard.
