Car Care Discussion Car Detailing Info, Wax, Wheel Polish, Interior Cleaning Tips for the Corvette
Small rockchips
Old Aug 31, 2009 | 11:56 AM
natedmac's Avatar
natedmac
Default Small rockchips
Hello,
I have some small tiny looking rock chips in the paint. I am not ready or able to have the car repainted. It also looks like there might be some small scratches. I am looking for the best way to clean it up and make it look better and hide these spots. I am hoping that with a good hand washing and possibly waxing the car that i can I hide alot of it and get it to look better.
natedmac
Old Aug 31, 2009 | 05:21 PM
MikePhillips's Avatar
0MikePhillips
Former Vendor
Most people, not saying you're like this, but most people when they want rock chips repaired they want the ugly chips t no longer be visible, they don't want any raised blobs of touch-up paint where the chips used to be, they want it to be relatively easy to do or in-expensive to pay for and if they pay for it then they again, want all of the above.
The problem is doing quality touch-up paint work is difficult and it's usually not fast and finding someone that's really good at it and will even take the job is even harder.
The most common problems are,
The built-in paint brush deposits to much touch-up paint thus you go from a chip to a blob.
Sometimes people will try to sand the blob flat and then somehow remove their sanding marks. The touch-up paint is soft compared to the clear coat finish so the sanding marks come out of the touch-up paint easily but not the clear coat so now you have a shiny touch-up spot a scratched paint surrounding the shiny spot.
If you rub or buff to hard on the touch-up paint you will physically pull it out of the chip so now you're back to where you started except how you have sanding marks still surrounding the chipped area.
Hmm... did I miss anything?
If the car is black, get a black Sharpie and dab some permanent ink into the chipped area, not the best fix but quick and easy and from 10 feet away you don't see the chip. Sometimes you can get away with this using a red Sharpie on a red car.
The best, easiest fix I've ever seen is the Dr. Color Chip repair system, if you can find a person that offers this it works well and is affordable.
Old Aug 31, 2009 | 07:18 PM
dvilin's Avatar
dvilin
Agree with all in the previous post, give Dr. Color Chip a try.
Old Sep 1, 2009 | 11:15 AM
natedmac's Avatar
natedmac
Thanks I will look at it and see if it will work for what I need.
To Small rockchips
