Car Care Discussion Car Detailing Info, Wax, Wheel Polish, Interior Cleaning Tips for the Corvette
Polish
Old Jan 23, 2010 | 06:32 PM
retaf87's Avatar
retaf87
Default Polish
Does anyone use polish prior to waxing? I currently use NXT 2.0 and shine is pretty darn good but wonder if polish will add more luster.
Old Jan 23, 2010 | 08:13 PM
dvilin's Avatar
dvilin
The first time I detailed the car I used polish prior to applying wax. That was it, now I just apply wax. If you want to have the best shine, you probably should wash car with dawn, clay bar it, apply polish and then wax.
Old Jan 23, 2010 | 08:18 PM
tlc0706's Avatar
tlc0706
Polish preferably with a PC
Old Jan 23, 2010 | 10:10 PM
steve8's Avatar
steve8
Only if you want it to look good.
Clay/machine polish/Zaino once/year for me.
Old Jan 23, 2010 | 11:18 PM
CrazyMagMan's Avatar
CrazyMagMan
St. Jude Donor '05
We wash with Meguiar's Gold Class and do a two bucket wash(one for rinsing), then clay, then wash again, then apply Wolfgang Sealant, then apply Zaino Z5, Zaino Z6 detailing spray, and then finish with Zaino Z2(with ZFX). You can do multiple coats of Z2(with ZFX), but use the Z6 between them. By doing the multiple coats of Z2(with ZFX), the finish will just look wetter and wetter and deeper and deeper until you can't believe how good the car looks. Hope this helps!!!
Old Jan 24, 2010 | 09:57 AM
Killrwheels@Autogeek's Avatar
0Killrwheels@Autogeek
Former Vendor
Megs NXT and NXT 2.0 are a synthetic type wax with the lightest of paint cleaners in them. Far from a polishing agent. Polishing, using a machine with abrasive pastes and pads will indeed offer greater outcome and finish. You can then still coat/protect the paint with NXT as desired. They even make a Spray Wax booster to use after washing to increase the protection and good looks.
Heres what polishing really is and should do:
http://www.autogeek.net/detailingtips.html
Call us if you need help or hints with products/machines/pads to help. We aim to earn your business before, during, and after a sale.
Old Jan 28, 2010 | 09:41 AM
zoomzoom mazda5@properautocare.com's Avatar
0zoomzoom mazda5@properautocare.com
Former Vendor
Many people assume that waxing and polishing are synonymous. In fact, they are two different processes.
Polishing deep cleans the paint, removes oxidation, old wax & minor swirls, and rejuvenates the top paint layer. It prepares the surface for waxing and insures a uniform, high-gloss shine.
NXT works great after you get some proper polishing on the surface of your ride. And if you want to bring it to a high state of wetness then Blackfire Wet Diamond All Finish Paint Protection is the way to go.
Here's a great post in polishing from ProperAutoCare:
When it comes to using polishes such as Meguiar’s M105 Ultra Cut Compound and Meguiar’s M205 Ultra Finishing Polish, regardless of the machine you choose to use, ProperAutoCare.com recommends starting with the least aggressive method possible. This would be Meguiar's M205 with either a Lake Country Flat 6.5 inch Black Finessing Pad or Meguiar's Soft Buff 2.0 Black Finishing Pad.
If this combination does not provide the results necessary, increase the aggressiveness of the technique (longer working time, more pressure, more power) or increase the cut of the product and switch to a medium polishing pad. The next step up would be Meguiar’s M205 Ultra Finishing Polish used with a Lake Country Flat 6.5 inch White Polishing Pad or Meguiar's Soft Buff 2.0 Yellow Polishing Pad.
If this combination does not provide the desired results, increase the aggressiveness of the technique or product selection. The next step would be Meguiar's M105 Ultra Cut Compound on a Lake Country Flat 6.5 inch White Polishing Pad or Meguiar's Soft Buff 2.0 Yellow Polishing Pad. Note that polishing with M105 will often require a second, follow-up polishing step with M205 to achieve the highest gloss and clearest, swirl free finish. Never mix polishes on the same pad. Switch to a clean, fresh pad included in the kit. If this combination is still not garnering the results you are looking for, increase the aggressiveness of the technique or the product.
Meguiar's M105 Ultra Cut Compound used with a Lake Country Flat 6.5 inch Orange Power Pad or Meguiar's Soft Buff 2.0 Burgundy Cutting Pad is an aggressive combination and is capable of “leveling out” most paint defects in one or two applications. If using Meguiar’s M105 Ultra Cut Compound is necessary, follow up with Meguiar’s M205 Ultra Finishing Polish to remove any light polishing haze and restore full clarity and a swirl free finish to the paint. Always test your combination on a test spot, and inspect in good lighting before proceeding to copy that combination over the entire vehicle.
Least to most aggressive:
M205 used with a “Finishing Pad”: Will remove very light defects and result in a high gloss, swirl free finish.
M205 used with a “Polishing Pad”: Will remove moderate to light defects and compounding marks, and results in a high gloss, swirl free finish on most paints.
M105 used with a “Polishing Pad”: Will remove moderate to heavy defects and will often require follow up polishing with M205.
M105 used with a “Power” or ”Cutting Pad”: Will remove moderate to heavy defects on most paints and will often require follow up polishing with M205.
Pad Priming: The new micro non-diminishing abrasives from Meguiar's require that the pores of the pad are evenly primed with product for fastest cutting and highest gloss. It is recommended to "prime" a fresh, dry pad one of three ways:
The Kevin Brown Method (KBM): Apply a liberal amount of polish on the surface of the pad and massage the product into the pores with your fingers until the surface is covered in a fine film of polish. Remove excess polish from the pad, so that it feels slightly damp, by lightly pressing a cotton terry or microfiber cloth against the pad while it spins.
Meguiar's M34: Meguiar's recommends misting the dry pad with M34 Final Inspection, then drawing two lines of product, in an X fashion, across the diameter of the pad. M34 will help the polish spread across the pad during the initial polishing application.
Hybrid: ProperAutoCare.com recommends using a hybrid pad priming system to save on material costs and increase ease of use. Mist the dry pad with M34 Final Inspection then draw an X across the pad. Quickly massage the polishing with your fingers into the pad and cover as much surface as possible.
Regardless of the priming method you choose, once the pad has been primed, apply a small amount of polish to the pad between sections. Three “dime sized” amounts, applied to the outer 1/3 of the pad are sufficient.
Polish one small section at a time, two feet by two feet, per application. Start by placing the pad on the paint and spreading the polish out, then turn the polisher on. Using firm pressure and overlapping left to right, right to left strokes cover the area to be polished.
Polish first going left to right.
Make a second pass over the working area using overlapping “up to down, down to up” strokes. M105 and M205 do not require a typical “buffing cycle” to break down the abrasives. Repeat this cross hatch pattern until the defects are removed or the polish begins to dry. Then reduce pressure and make a few more passes over the area to ensure a high gloss finish.
Create cross-hatch pattern going up & down.
Machine speed has much to do with your confidence level as you learn to use these polishes. We recommend using speed 5 on the PC 7424 or Meguiar’s G-110 and a speed of 3.5-4 on the Flex XC3401VRG Dual-Action Polisher. Overlap your strokes, using a “slow arm speed” while applying firm pressure. We have found success moving the polisher one to three inches per second allows the polish to correct most blemishes.
The amount of “work” or “cut” accomplished with a non-diminishing abrasive is dependent on the pressure applied to the polisher. For maximum cutting action with the Flex XC3401VRG Dual-Action Polisher, apply 15-20 pounds of pressure on the face of the machine. When using the Porter Cable 7424 or Meguiar’s G110 random orbital polishers, use enough pressure to slow, but not stall the rotation of the pad. On your final passes over the work area, reduce the pressure and lightly move the machine over the surface to allow the abrasives to jewel away any micro marring left from your polishing.
After polishing a section, remove residue immediately with a high quality microfiber cloth such as our Dragon Fiber Perfect Shine Buffing Cloth.
Because Meguiar's M105 Ultra Cut Compound and Meguiar's M205 Ultra Finishing Polishes' abrasives do not breakdown in the traditional sense, the polishes can be sensitive to contamination. During the polishing process, a trace amount of paint is removed, this can cause the non-diminishing abrasives to “clump” together with the spent paint particles. This can increase the polishing haze left on the paint from heavy polishing, effecting the finish left behind.
ProperAutoCare.com recommends cleaning your pads often by pressing a cotton terry or microfiber cloth against the pad while it spins on the machine. To completely wash the pads use Snappy Clean Pad Cleaning Powder.
Angelo (Retired USAF E-8)
www.ProperAutoCare.com
Alway toll free 800-628-7596
To Polish
