Car Care Discussion Car Detailing Info, Wax, Wheel Polish, Interior Cleaning Tips for the Corvette
Clay Question
Old Mar 18, 2010 | 12:04 AM
tommym's Avatar
tommym
Default Clay Question
Hey guys, I plan on claying my car this weekend. I read that a lot of you use Z7 when claying. Is there something besides that I could use, preferably something I could pick up at a B&M? First time claying, so I just want to make sure I do it right.
Thanks,
Tommy
Old Mar 18, 2010 | 12:33 AM
vettluver's Avatar
vettluver
I have used a quick detailer (megs) mixed about 60/40 detailer/distilled water and it worked fine. The QD gets expensive if you use it as you should to keep your panels well lubricated while claying.
Old Mar 18, 2010 | 01:11 AM
Onyasix's Avatar
Onyasix
Most any of the detail sprays or diluted car soaps should work fine. You can usually find spray lubricant made for claying at most auto stores.
Old Mar 18, 2010 | 07:04 AM
Sleper's Avatar
Sleper
Any detailer, car wash soap, I have even used foaming glass cleaner. Just make sure you keep the surface lubed or you will mar and create a bigger problem. Good luck
Old Mar 18, 2010 | 09:28 AM
TOGWT's Avatar
TOGWT
From: Ponte Vedra Beach / London State: Dazed and confused
Application –a thin film of lubrication (see Detailer’s Clay Lubrication) provides a safety barrier that enables the clay to hydroplane across the surface. In other words, the clay is aquaplaning on a micro-thin film of lubrication between it and the paint surface removing the (protruding) surface contaminants by abrasion and encapsulation by the malleable clay.
Without lubrication the clay will abrade the paint surface much like a dry-sanding block and will produce significant fine surface marring. When you start the clay process you’ll feel resistance as you glide the clay with its lubricant, this is normal, the resistance will lessen as the contaminants are removed, once there is no more resistance you can move to the next 2 x 2-foot section
Old Mar 18, 2010 | 09:45 AM
MikePhillips's Avatar
0MikePhillips
Former Vendor
Watch this...
How detailing clay works and how to use detailing clay to remove above surface bonded contaminants
Old Mar 18, 2010 | 12:44 PM
Snowwolfe's Avatar
Snowwolfe
Half teaspoon of liquid dishwashing detergent per quart of water. Shake up well and use all you want. Been claying our cars for years with this mixture and using anything store bought is just a waste of money.
Old Mar 18, 2010 | 09:33 PM
tommym's Avatar
tommym
Thanks for the info! Hopefully all will go well.
To Clay Question
