Car Care Discussion Car Detailing Info, Wax, Wheel Polish, Interior Cleaning Tips for the Corvette
APC question
Old Apr 25, 2010 | 12:30 PM
tlc0706's Avatar
tlc0706
Default APC question
As Meg's APC & APC+ both dilute to clean engines, tires and interior...What is the difference in the two? AND are these really good enough for really dirty jobs as my DD needs the engine cleaned, so should a purchase of Meg's Super Degreaser be necessary?
Thanks,
Tom
Old Apr 25, 2010 | 01:20 PM
Innovative714's Avatar
Innovative714
I prefer APC+ as it is more versatile when it comes to interior cleaning. It also has fabric brightners, softners and a low ph which leaves the interior perfect so long as you mix it accordingly. When it comes to engine cleaning the APC+ works very well also, have some "Stoner" Tarminator around for any grease, oil or gunk build up. You should also have a large assortment of brushes for your engine cleaning.......It is always a great idea to liberally spray water on all the painted areas around the engine compartment (fenders, bumper) before applying the APC+. This way any degreaser will not spot, streak or stain the painted areas. After doing your engine cleaning be sure to thoroughly blow out all areas, and dress and protect rubber with the treatment of your choice.
Old Apr 25, 2010 | 02:09 PM
Killrwheels@Autogeek's Avatar
0Killrwheels@Autogeek
Former Vendor
I always thought it was more to do with scent, APC+ is more of a end user design and scent (orange) whereas the original APC was for more professional settings. APC+ is suppose to foam less too.
Old Apr 25, 2010 | 03:25 PM
SSTG's Avatar
SSTG
APC+ is citrus based also.
Old Apr 25, 2010 | 05:59 PM
zoomzoom mazda5@properautocare.com's Avatar
0zoomzoom mazda5@properautocare.com
Former Vendor
Meguiar's APC D103 is much more then you think, it provides mixtures for heavy cleaning of engines and tires, fast interior cleaning, as well as low foam ratio for use in carpet and upholstery extraction machines. Leaves carpet clean, smelling pleasant, and the fibers soft with no sticky residue. Safe for clear plastic, glass and leather. With the cleaning power and versatility of Meguiar's All Purpose Cleaner Plus you could almost replace all your cleaning products with one bottle of Meguiar's APC+.
Old Apr 27, 2010 | 12:24 AM
tlc0706's Avatar
tlc0706
Thanks Guys.....that was a help......
Tom
Old Apr 28, 2010 | 04:37 PM
03 Z-oh-6's Avatar
03 Z-oh-6
Optimum Power Clean APC is the best I've used. APC+ is good, but it's not safe for paint. OPC can do everything APC+ can and it's safe on paint too. Howver, OPC is twice the price of APC+
To APC question
