Car Care Discussion Car Detailing Info, Wax, Wheel Polish, Interior Cleaning Tips for the Corvette
Removing Bugs From Drive
Old Apr 28, 2010 | 08:40 AM
KneeDragr's Avatar
KneeDragr
Default Removing Bugs From Drive
What do you guys do to remove the bugs from the front/hood area after a drive?
Do you let them sit until the car cools, knowing they may scratch when removed then?
Or do you remove them right away while they are soft, even though the paint is more vulnerable when hot?
What do you use? A detail spray, warm water and sponge, or warm soapy water?
Old Apr 28, 2010 | 11:30 AM
TOGWT's Avatar
TOGWT
From: Ponte Vedra Beach / London State: Dazed and confused
Heat (vehicle paint temperature of 90.oF+ creates a very aggressive reactivity of the acids that are present, which causes surface etching, so they should be removed without delay, at lower temperatures (40oF or less) there’ s no reactivity and therefore little or no etching.
To remove - pre-soak heavy bug contamination with an isopropyl alcohol (IPA) soaked towel(s) and let dwell for 4-5 minutes before removing. Then use a Safe Scrub Bug & Tar Pad and some warm, soapy water. It’s completely harmless to the paint or glass surfaces, a very efficient and safe way of removing harmful baked on bug debris due to its non-abrasive nature. The open-cell construction 'grabs' foreign matter on your cars paint surface and safely removes it.
Old Apr 28, 2010 | 11:46 AM
Detailed Image's Avatar
0Detailed Image
Former Vendor
I spray the Chemical Guys Bug Bugger & Tar Remover on the build ups and then I may just wash the front of the vehicle with the Optimum (OPT) No Rinse Wash & Shine New Formula (ONR). The Bug Bugger does an awesome job of quickly breaking down any build ups.
Old Apr 28, 2010 | 12:15 PM
capevettes's Avatar
capevettes
CF Community Team
Active Streak: 90 Days
2016 C2 of Year
2015 C3 of Year Finalist
I take a large cotton towel, soak it thoroughly with clean water and lay it over the nose of the car for a few minutes and let it soak the bugs. Slide the towel off taking alot of the bugs with it. I then use Zaino Z6 spray detailer with a microfiber.
Old Apr 28, 2010 | 06:35 PM
Zorlac's Avatar
Zorlac
I break out the sandblaster
Old Apr 28, 2010 | 07:59 PM
Killrwheels@Autogeek's Avatar
0Killrwheels@Autogeek
Former Vendor
keep a small travel size spray bottle and soft towel in a ziplock in the rear hatch. Fill the bottle with Poorboys Bug Squash or Einszett Insekt Remover. Quick, fast, effective.
Old Apr 28, 2010 | 09:29 PM
JVM225's Avatar
JVM225
St. Jude Donor '06
I have a 3M Clear Bra on my front bumper cover. It's an investment, but I find it's a lot more forgiving than the clear coat when it comes to removing bugs after a long drive.
I usually have a bottle of Chemical Guys QD in the car that I soak the area with, and the bugs just wipe off with no etching etc..
Old Apr 29, 2010 | 10:25 AM
Jim Shearer's Avatar
Jim Shearer
Originally Posted by capevettes
I take a large cotton towel, soak it thoroughly with clean water and lay it over the nose of the car for a few minutes and let it soak the bugs. Slide the towel off taking a lot of the bugs with it. I then use Zaino Z6 spray detailer with a microfiber.
I too use this method with great success. I leave the towel on the bugs for at least 10 minutes, preferably 15 minutes. Turn the towel over and GENTLY wipe away the bugs. Use your favorite detail spray to get any further bug juice off.
Old Apr 29, 2010 | 11:01 AM
KneeDragr's Avatar
KneeDragr
Thanks guys, some good ideas in here.
Old Apr 29, 2010 | 11:03 AM
Jim Shearer
You will be surprised at how easy the bugs come off after soaking for 10 to 15 minutes. I drove my new ZR1 from Bowling Green to Effingham, IL in late September. The front was covered with hundreds of bugs. I was sick. I got a towel out and used the method described and the finish was perfect!
Old Apr 29, 2010 | 12:19 PM
blackmachdown's Avatar
blackmachdown
immediately after w/ onr no marring issues
To Removing Bugs From Drive
