Car Care Discussion Car Detailing Info, Wax, Wheel Polish, Interior Cleaning Tips for the Corvette
Buffer Pad Cleaning
Old May 16, 2010 | 07:17 AM
92Beast's Avatar
92Beast
Default Buffer Pad Cleaning
How do you clean you buffer pads with OUT spending $135 for a plastic bucket and gizzmo?
Old May 16, 2010 | 09:56 AM
Bat Man's Avatar
Bat Man
If the pad is just lightly used, I'll spray some detail spray on it, then run warm water through it, and wash it with my hands or a soft tooth brush.
If the pad is heavily saturated, I use detail spray first, then i use diluted dawn dish soap to get it out.
Old May 16, 2010 | 10:06 AM
BlueSpeed's Avatar
BlueSpeed
This is what worked for me, I diluted dawn in a bucket of water and let the pads soak for a couple of hours then thoroughly rinse and air dry in shade.
Old May 16, 2010 | 10:15 AM
Killrwheels@Autogeek's Avatar
0Killrwheels@Autogeek
Former Vendor
http://www.autogeek.net/dp730.html
Mix up as little or as much as needed in a pale and toss when done.
Old May 19, 2010 | 07:03 PM
zoomzoom mazda5@properautocare.com's Avatar
0zoomzoom mazda5@properautocare.com
Former Vendor
Snappy Clean with water in a bucket, wash by hand and then rinse = $ 3.99 and some 5-10 minutes of your time...........
Sold at ProperAutoCare
Angelo
www.ProperAutoCare.com
800-628-7596
Old May 19, 2010 | 07:34 PM
Rez90's Avatar
Rez90
I use Pinnacle XMT pad cleaner. works great.
Old May 19, 2010 | 07:37 PM
Former Vendor
thanks, always forget that one too
http://www.autogeek.net/xmt-pad-cleaner.html
Old May 20, 2010 | 06:37 AM
Sleper's Avatar
Sleper
I spray with degreaser, use power washer, take in side and rince with warm water numrous times, air dry. Cheap and works great
Old May 25, 2010 | 11:34 PM
James92's Avatar
James92
a little simple green in a bucket of warm water for 10 minutes and rinse clean.
To Buffer Pad Cleaning
