Car Care Discussion Car Detailing Info, Wax, Wheel Polish, Interior Cleaning Tips for the Corvette
Machine polisher problem
Old Aug 3, 2010 | 06:11 PM
CStewTAMU's Avatar
CStewTAMU
Default Machine polisher problem
Pretty obvious. The sander pad I removed is a male part and the new polisher back plate is female with much larger threads.
Tell my I am not screwed. SURELY there is a convertor. I was under the impression most of these tools had a universal attachment.
Old Aug 3, 2010 | 07:06 PM
Killrwheels@Autogeek's Avatar
0Killrwheels@Autogeek
Former Vendor
Are you using a dual action buffer ??? Looks like the flexible backing plate is actually for a rotary. Here is an option:
http://www.autogeek.net/daadapter58x11.html
Old Aug 3, 2010 | 07:35 PM
CStewTAMU's Avatar
CStewTAMU
Thanks...exactly what I was looking for.
I'll be using PC 7336. I think that's DA. It's got 6 speed settings. It swivels and spins...guess that's what you mean.
Old Aug 3, 2010 | 07:53 PM
Former Vendor
you are indeed correct, the posts are different between rotaries (circular) and random orbitals. Two choices really , one is to exchange backing plate to correct model or second is to use the adapter that I forwarded in earlier post. (tighten well)
Old Aug 4, 2010 | 08:40 AM
meghan@autogeek.net's Avatar
0meghan@autogeek.net
Former Vendor
Good way to look at the backing plates is the Rotary is a female and the DA is a male!
If you are using a Porter Cable you will need the male DA backing plate like this one.
Here is Rotary (female) backing plates
To Machine polisher problem
