FLEX PE14-2-150 Rotary Polisher Pre-Order Special At ProperAutoCare.com
Former Vendor
Flex PE14-2-150 Polisher Power-Plus in a Lightweight Package From ProperAutocare.com.
Pre-Order now and receive a Flex Utility Bag, one 5" Flexible Backing Plate, and two 5.5" Flat Lake Country Polishing Pads of your choice at no additional cost. Includes FREE UPS Ground Shipping!
Just pay a $100.00 refundable deposit now and the rest when they are available first quarter of 2011.
Flex Tools used their knowledge and I believe they used some German sports car ingenuity to create their Flex PE14-2-150 Polisher. This polisher is lightweight, smooth running, ergonomic in design, with aerodynamic air flow to keep the machine running cool. Sounds like the makings of an German sports car anyway.
The Flex PE14-2-150 Polisher is made in Germany with all the features you would want in a machine polisher. The speed control allows a 600 - 2100 RPM speed range. Good idea since there are few occasions where a higher speed is needed. And, it only weighs 5.6 pounds meaning less fatigue on you.
Other features of the Flex PE14-2-150 Polisher include the spindle lock button located to avoid accidental contact, rubber-coated contact areas for safe operation, rubber-coated grip for comfort and control, 5/8" x 11 threaded spindle, short distance between backing plate and machine for safer operation and machine control, rigid low-wear gear box for continuous polishing and optimized noise levels, optimized air guidance system for better cooling, slim yet powerful 10 amp motor with a high capacity fan to keep the machine cool, slow-start mechanism with locking trigger, and a 13' rubber cord.
Features of Flex PE14-2-150
The Optimized Air Guidance System of the Flex PE14-2-150 Polisher is the heart of this machine. This is a welcome addition for professionals and consumers who are doing constant polishing on larger surfaces. The air guidance system forces air throughout the machine to keep all areas cool and operational.
Product specifications of the Flex PE14-2-150 Polisher.
Model PE 14-2 150 US
Back-up pad diameter max . 6“
Polishing pad diameter max. 8“
Speed w/o load 600 – 2100/rpm
Power input 10 Amp, 1400 Watt
Power output 880 Watt
Tool fixture 5/8“
Length 15.75“
Height 4.7“
Weight 5.6 lbs
Cord 13 feet
Includes: 1 Side Handle
Pre-Order now and receive a Flex Utility Bag, one 5" Flexible Backing Plate, and two 5.5" Flat Lake Country Polishing Pads of your choice at no additional cost. Includes FREE UPS Ground Shipping! Free Shipping only to the Continental 48 United States.
Please remember this polisher normally does not include pads or a backing plate.
Angelo
Email me at Angelo.g@properautocare.com
Toll Free 1-800-628-7596
The Most Talk About Sealant In the World Blackfire Wet Diamond
Tool fixture 5/8“
Length 15.75“
Height 4.7“
Weight 5.6 lbs
Cord 13 feet
Angelo
Former Vendor
Remember everyone were the first the bring the FREE goodies on the Flex Pre-order so if you snooze you lose! so don't start kicking tires thinking what to do, pre-order your new Flex with all those FREE goodies from your friends at ProperAutoCare.com now before it's too late.....
