Car Care Discussion Car Detailing Info, Wax, Wheel Polish, Interior Cleaning Tips for the Corvette
Need advice
Old Mar 29, 2011 | 07:22 AM
BT ZR1's Avatar
BT ZR1
2009 ZR1 SN 1166
Default Need advice
I have some localized scratches on the hood which are only visible under strong light ( car came this way) otherwise the black is swirl free and very good looking. I tried meg 105 and then menzrena polish. Scratches stll seem to be there. I think I'm afraid to spend time on the area for fear of going to deep.Which lc pad? Orange?
Old Mar 29, 2011 | 09:53 AM
Killrwheels@Autogeek's Avatar
0Killrwheels@Autogeek
Former Vendor
you can start with white pad and 105 initially and move to orange as desired. You will then want to come back to a lighter pad and compound (ie. finishing polish) to followup. If you cannot feel them with fingernail you should be able to reduce or remove them.
Old Mar 29, 2011 | 10:38 AM
Joz132's Avatar
Joz132
St. Jude Donor '12-'13
I had spectacular results using:
Menz SIP / LC Hydro Cyan pad
Menz 085rd / LC Hydro Tangerine pad
used on my Monterery Red vert.
Old Mar 29, 2011 | 11:25 AM
BT ZR1's Avatar
BT ZR1
2009 ZR1 SN 1166
Thanks, i will try again, I thought i made enough section passes. I'm guessing i should have spent more time
To Need advice
