Car Care Discussion Car Detailing Info, Wax, Wheel Polish, Interior Cleaning Tips for the Corvette
Looking for basic cheap benign quick cleaner
Old Apr 5, 2011 | 02:08 PM
ThrottleUp's Avatar
ThrottleUp
Houston Events Coordinator
Default Looking for basic cheap benign quick cleaner
Ok,
I know we are product-focused (I know I am) and our grandmothers would faint at how many commercially available products we buy to solve most household challenges. It's as if we don't trust that we could comeup with something as good as somebody selling something. And I'm sure many of these products are much better than what I could even begin to think-up.
BUT........ in order to do a simple quick clean-up of say a one-inch square area of my car that I drop something on (say Hershey's chocolate syrup), can't I just mix-up some "mild-detergent" with water in a spray bottle, spray it on and gently blot-up with a clean dry fluffy towel?
I know Dawn's won't work as it's too strong and is maybe a bit too caustic (I guess)...... maybe bathsoap leaves a residue.... so I'm not sure what is a "mild-detergent". This could also possibly help dilute or wash-away a bit of the hard water deposit I failed to notice when I washed the car. Is it maybe a car-wash product I should use (but without getting it all sudsy and making a big splash all over)?
Any suggestions? Maybe I'm a contrarian but just thought it might be something so obvious and simple I'm overlooking and all you already have that solution thought-through??
Thanks any comments, suggestions.
P.S. I do the Museum pick-up on the 20th and so getting in the "preparation mode".
Old Apr 5, 2011 | 07:51 PM
Killrwheels@Autogeek's Avatar
0Killrwheels@Autogeek
Former Vendor
save yourself some time and effort and grab a product that will have you happy with results in many different manners from quick detailing to actual washing or cleanups. It is also compatible with all waxes and sealants so you wont need to reapply them after every use.
http://www.autogeek.net/optimum-no-rinse.html
Old Apr 6, 2011 | 07:31 PM
zoomzoom mazda5@properautocare.com's Avatar
0zoomzoom mazda5@properautocare.com
Former Vendor
Optimum Opti Clean will clean and shine every surface on your car with a spray and wipe. The revolution formulation of Optimum Opti Clean will clean and protect painted surfaces, class, vinyl, plastic, metal, etc. The combination of substantive polymers and cleaners is safe on all surfaces to cleans and shines leaving a glossy protective finish. Optimum Opti Clean will give you a just-washed look in only a few minutes. Use Opti Clean on dusty and lightly soiled surfaces to quickly revive your paint.
Optimum No Rinse Wash and Shine (ONR)uses millions of microscopic polymers that bond to the paint's surface and dramatically increase lubricity during the wash process. Dirt and grime are encapsulated then removed with out scratching or inducing swirl marks. Increase your gloss and also Optimum No Rinse and Shine can also be diluted and used as the ultimate gloss enhancing quick detail spray.
http://classic-motoring.stores.yahoo.net/optimum.html
Old Apr 6, 2011 | 07:47 PM
ThrottleUp's Avatar
ThrottleUp
Guys, I do like what these two products are described as doing...... the only thing was that I was kind of hoping that a simple cleaner that could help dissolve ocassional water spots or bird droppings, or even something odd like spilt choco syrup, without doing something so complicated as bonding with the paing's surface. I'm new at this but how many products can I have "bonding" at the same time? If I applied a first polymer coating, then find myself with the spots I mentioned, I was just looking for a product that would easily, safely and simply help me remove the problems.
I don't mean your products are over the top or anything, but it reminds me of when I decided to keep my meeting notes on a scratch pad made of paper instead of whipping out a computer to write it down with. I know both methods work, but which one is kind of "built" for the way I operate?
Still, you've interested me in them and it looks like there's probably a place for them in my garage. By the way zoomzoom, I like that you offer free shipping under $69, it's so easy to spend that much these days.......
Thanks again, I may end-up just mixing a very diluted dishwashing liquid in an empty spray bottle...... not sure yet.
Old Apr 6, 2011 | 09:15 PM
Former Vendor
You will find ONR does all that you need and more without issue. If you already have a good sealant on their, it will work with it and reduce those spots and emulsifiers will work on dirt and other stuff. You can certainly also consider any number of Quik Detailer products or rinseless washes too. Ultima makes a great one !
http://www.autogeek.net/ultima-waterless-wash-plus.html
Old Apr 7, 2011 | 08:01 AM
Former Vendor
Thank you ThrottleUp, if you got the time, then call me at PAC ( 800-628-7596, I'm a live person that works there ) and we can find the best solution for you can remember that you like the FREE shipping over 69 bucks too!
Angelo
To Looking for basic cheap benign quick cleaner
