Car Care Discussion Car Detailing Info, Wax, Wheel Polish, Interior Cleaning Tips for the Corvette
Help Needed, Zaino Application
Old Apr 23, 2002 | 03:01 PM
KDuniverse's Avatar
KDuniverse
Default Help Needed, Zaino Application
Ok, finally got my new zaino order. This zfx is skimpy for $20, but I hear its worth it. Haven't zaino'd the car in months. Should I Z1-Z2-Z5? What should I do?
Old Apr 23, 2002 | 03:09 PM
Silver2002's Avatar
Silver2002
Cruise-In III Veteran
St. Jude Contributor
Default Re: Help Needed, Zaino Application (KDuniverse)
If you have ZFX then you don't need to use any Z1. If you have some minor swirls use the ZFX/Z5, if not use the ZFX/Z2. Remember you can apply 3 coats per day with the mixture. Mix only 1/2 of the small bottle so that you don't waste any. Make sure to clean the bottle out good after use so that you can reuse it.
Old Apr 23, 2002 | 03:20 PM
KDuniverse's Avatar
KDuniverse
Default Re: Help Needed, Zaino Application (Silver2002)
Why is it limited to only 3 uses per day?
Old Apr 23, 2002 | 03:28 PM
Silver2002's Avatar
Silver2002
Recommendations from Sal is that 3 coats should be the per day, I believe that it is in the instructions as well.
Old Apr 23, 2002 | 06:50 PM
hcvone's Avatar
hcvone
3 coats a day is as much as you want to put on, it takes some time to fully cure.
To Help Needed, Zaino Application
