I just applied a coat of Dodo Hard Candy today. I was planning top top it with a layer of Dodo Red Tropical Mist Protection Detailer however it says on the bottle not to apply over a fresh coat of wax.
When I read the product overview it says to use it as a wax boosting detailer and sealant.
What is considered fresh wax?
Is there a cure time to the Red Mist before it should be exposed to UV, etc?
I was hoping to add a protective layer over the Dodo Hard Candy before hitting the streets again.
Dodo Juice Tropical Spray can be used alone or as a booster over many of their waxes. Because some of the solvents used in waxes can still be released after intial application, its best to avoid topping a new coat for a couple hours. You should be able to top it within 12-24 hours max.
