Car Care Discussion Car Detailing Info, Wax, Wheel Polish, Interior Cleaning Tips for the Corvette
Claybaring Quick reponse please
Old Dec 6, 2011 | 09:12 AM
QUAKEJAKE's Avatar
QUAKEJAKE
Default Claybaring Quick reponse please
I'm in the process right now.Simply can you claybar clearbra safely?
Old Dec 6, 2011 | 10:28 AM
BarryK's Avatar
BarryK
i personally avoid claying or doing ANYTHING over clear coverings. That stuff scratches and mars so easily than a single grain of sand accidently in the clay will put in scratches you will not be able to remove from the clear cover.
realistically, claying shouldn't harm the clearbra at all but since they scratch so easily and scratches can't be removed from them I just don't do anything with clear coverings except simple wash and wipedown, no claying, no polishing, etc
Others may disagree but this is what I came up with from experience
Old Dec 6, 2011 | 12:04 PM
QUAKEJAKE's Avatar
QUAKEJAKE
Originally Posted by BarryK
i personally avoid claying or doing ANYTHING over clear coverings. That stuff scratches and mars so easily thanking a single grain of sand accidently in the clay will put in scratches you will not be able to remove from the clear cover.
You don't do anything for shine and UV protection?
Old Dec 6, 2011 | 12:51 PM
BarryK's Avatar
BarryK
I owned my own detailing company and every car that came in with the clear coverings I did as described above. It should be fine if you want to put wax over the clear but there really is no need. Keep in mind that wax or sealant is designed for protection of PAINT and/or PAINT CLEARCOAT, not for a plastic type coating. I never saw any advantage or benefit to waxing or sealing over on the clear covering plus it just creates more work trying to get the remaining wax or sealant away from the edges of the clear after applying the product.
The clear covering itself is now your paint protective layer rather than a wax but the clear covering itself doesn't require a wax for protection like paint does.
Old Dec 6, 2011 | 01:34 PM
JVM225's Avatar
JVM225
St. Jude Donor '06
I don't clay my clear bra. It cost too much to replace if I mar it up. I just wash it like I do the rest of the car and wax it when I wax the rest of the car.
The whole idea of it is that it will take the beating that the paint would otherwise take up there. With that in mind it's inevitable that there might be a battle scar or two. If it gets real bad it might be time to replace it. I replaced a lower portion of my clear bra once already. If that's the plan then I might try a polish on it before I had it replaced. You'd have nothing to lose.
If you have relatively minor things that you want to take out try a cleaner/wax on the clear bra. That might get it a little better.
I was told by my installer that the 3M product he put on my car can be polished just like the rest of the car, but it just doesn't sit well with me and I would only try it as a last resort.
Old Dec 6, 2011 | 05:03 PM
capevettes's Avatar
capevettes
CF Community Team
Active Streak: 90 Days
2016 C2 of Year
2015 C3 of Year Finalist
I wouldn't clay the clear bra. The only things I use on clear bras are non abrasives like spray detailers (Zaino Z6) or Zaino Clear sealant.
Old Dec 6, 2011 | 06:45 PM
CHUXDRM's Avatar
CHUXDRM
My installer recommended a liquid wax, which I have done. I realize you don't need it for protection, but I'd like to add a little slickness and shine to the car to match the rest of the car.
I've also wondered about using Plexus (sp?) that I use on headlight and taillight lenses?
Old Dec 6, 2011 | 09:30 PM
Texas_Venom's Avatar
Texas_Venom
I install film for a living and highly recommend you wax or apply a sealant to any paint protection film. The film is porous and needs to be protected jsut as the surface of the car. A good sealant will prevent bugs from staining the film and bird droppings from etching it. Leaving it without any wax or sealant will greatly shorten the life span of the film.
Old Dec 6, 2011 | 09:35 PM
Texas_Venom
Plexus has butane in it and will cause the film to yellow prematurely. It burns out the film causing it to yellow so I highly recomend not using it on soft plastics such as film. Lights are fine though.
Old Dec 6, 2011 | 10:25 PM
CHUXDRM's Avatar
CHUXDRM
Thanks for that clarification!
Old Dec 4, 2023 | 08:59 AM
Eric P's Avatar
Eric P
the ole related thread
Old Dec 4, 2023 | 08:33 PM
FYRARMS's Avatar
FYRARMS
Why did you bump a 12-year-old thread?
Old Dec 5, 2023 | 02:02 AM
Gixxerman's Avatar
Gixxerman
Moderator
St. Jude Donor '18 thru '25
Feel free to start a new thread
To Claybaring Quick reponse please
