Detail spray
#43
Z-6 Tip on the Z6 to help on cost. What I have done, I bought two 16oz spray bottles from Wal-Mart. I have taken my Z6 and cut it with water. I poured 8oz of the Z6 in separate spray bottle. You should have about 8oz left in the original Z6 bottle and 8oz in the spray bottle. Take a measuring cup and fill that up with about 5oz of water. Take one of the two bottles and pour the water into that bottle, shake it up to mix and set it aside. Repeat until the remaining bottles have been filled. Believe me; it makes these two bottles of the Z6 last a very long time because you now have 4 bottles. Or two bottles depending on how many bottles of Z-6 ordered. Trust me, I never had a problem in the 9 yrs of using Z-6 in this manner. And, you will save a lot of money by not having to replace Z6 often.
Also, buy a small 2oz spray bottle, two is better having one for a backup, the kind from Wal Mart. Typically, you can find them in the health care section, in the travel size product area. Fill one of them up with Z6. Use this small bottle when you apply Z6. It makes handling them easy and you do not have to struggle with trying to hold the big bottle. You will use this product lightly, spraying more so a mist over a 2ft x 2ft section and wipe off using a dedicated microfiber towel or 100% cotton towel. By the time you are finished with your vehicle, you should have used only about 1oz or so. If you use more than that, you used way too much. You will see how long these bottles will last.
