Free OEM Touch Up Paint Pen
#61
Former Vendor
St. Jude Donor '12
Tip: Shake thoroughly until you hear the mixing stainless ball for at least 1 min. The first time you use your touch-up pen, practice making lines, shapes or dots on the test paper. Thanks
#62
Former Vendor
St. Jude Donor '12
HI, as you can see we use the WA code for GM models since they used the same code several times through the years.
For an example : color code 972 in 1966 is Ermine White, WA code 2661, however color code 972 in 1968 is Polar White, WA Code 3465. They don't have the same formula.
Another worse example : color code 988 in 1968 is Cordovan Maroon Metallic, WA code 3821, however color code 988 in 1971 is Steel Cities Gray Metallic, WA Code 4150. In 3 years it went from red to grey.
That's why with the WA Code we always get the right formula ! Even GM uses the WA Code. If you are not sure you can Pm me, call me i'll be glad to assist you or even call your GM dealer. Thanks
#69
Pen arrived promptly and I have used it with good results, and recommend this product. Easy to use with no mess and a great color match on an 02 Electron Blue Z. Thanks.
#70
Former Vendor
St. Jude Donor '12
#77
I decided to do a side by side comparison between duplicolor and genie color on my pewter 99's licence plate filler since it has several marks in it from the previous owner hitting something while parking it looks like. When comparing both I can say the genie pen is very easy to use and much more precise then trying to use the brush on the duplicolor. As far as color there is a difference. The duplicolor blends very well but the geniecolor is a tad to light. It looks more silver. This is just my take on it, but I think it needs abit darker pigment to match.
#78
Ordered 2 weeks ago and still haven't received my pen in Texas. Anyone else taken this long? I've gotten stuff from China faster than this.
Did you ever get your order? I haven't!!!!!!
G
G
