Car Care Discussion Car Detailing Info, Wax, Wheel Polish, Interior Cleaning Tips for the Corvette
Dawn usage?
Old Jun 15, 2013 | 08:02 PM
09C6inWA's Avatar
09C6inWA
Default Dawn usage?
I've read recommendations on the site to use Dawn to strip the old wax off. I was watching Autoweek on Velocity and Pat Goss said it takes the oils out of the finish(?).
Does it do more harm than good or as long as you don't use it very often, it's not a big deal?
Old Jun 15, 2013 | 10:27 PM
Killrwheels@Autogeek's Avatar
0Killrwheels@Autogeek
Former Vendor
Dawn was suggested in the past to remove 'nuba based waxes. Modern sealants and coatings that have cured properly are much more durable and its hard to measure if Dawn can actually remove all or even part of newer waxes, sealants, and coatings. What is noted is that Dawn has chosen not to market a car wash or wax remover and as such should be left in the kitchen as designed.
If you want to remove and old product and start fresh, then consider using a paint cleanser, polish, or a dedicated wax remover like those from 3M and Griots.
Old Jun 16, 2013 | 07:53 AM
Crusher's Avatar
Crusher
Just an Ole Surfer Boy
NCM Ambassador
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VII Veteran
St. Jude Donor '04-'05-'08-'09-'10-'13-'14
Don't waste your money. Just use dawn. It will not do any harm and you only need to use it once. If it did any harm we would have heard about it a long time ago. For 99% of the time it is all you need. You just want to remove from your paint any waxes, oils, etc. from your paint that might interfere with whatever your detailing with. For that Dawn does the job just fine. At one time Rejex was not marketed for cars either but it didn't stop anyone from using it on their car.
Old Jun 16, 2013 | 09:05 AM
dvilin's Avatar
dvilin
Old Jun 16, 2013 | 08:04 PM
ztheusa's Avatar
ztheusa
Veteran: National Guard
Nothing special about "Dawn."
Old Jun 16, 2013 | 08:10 PM
JVM225's Avatar
JVM225
St. Jude Donor '06
Dawn is effective for removing carnauba wax. Occasional use, once or twice a year, won't hurt.
The only thing that I would be afraid of if using more often is it drying out rubber parts like weather-stripping.
Then again, most products that are strong enough to remove wax and sealant are probably capable of some kind of adverse effect.
Old Jun 17, 2013 | 02:14 AM
Mike2013's Avatar
Mike2013
St. Jude Donor '03-'26
If you were to use Dawn EVERYTIME you washed your vehicle then I believe you would be damaging the paint.
Old Jun 19, 2013 | 07:20 AM
bigcypress's Avatar
bigcypress
wow , that never dawned on me , thanks .
Old Jun 22, 2013 | 01:15 PM
tlvols75's Avatar
tlvols75
he he he i see what you did there
Old Jun 24, 2013 | 03:14 PM
Richard@Adams's Avatar
Richard@Adams
Premium Supporting Vendor
Default Dawn and old wax
If you clay your car that WILL remove the old wax.
Richard
To Dawn usage?
