What is best to use for dusting a clean car?
I have been using a California duster on my Corvette and Camaro for about 10 years now. I was recently told by the guy that restores cars and has done paint work for me that the California duster is the worse thing to use on paint and that it scratched the clear coat.
He said the best thing to use that will not do any damage is a Swiffer.
I am not sold on the swiffer and not sure if the Cali Duster is really scratching the paint or not. My Camaro was repainted about 6 years ago and definitely now has surface swirls and scratches (black car). I am wondering how much is to blame to the Duster.
What do you guys use to dust?
Former Vendor
Dry dust removal is a recipe for inducing major swirls and scratches into your finish.
For light dust/dirt removal, our Waterless Wash is perfect. It emulsifies and suspends the particle of dust off the surface, and when you wipe it with our waffle wave towels, safely lifts the dust form your paint without scratching it.
Take a look at this video to get a better idea of the process:
For many years I used a microfiber cloth. Sometimes I spray the cloth with detailing spray, sometimes just the surface of the car. The cloth is folded up and I use one section at a time then refold the cloth and repeat. Normally takes about 3-4 clothes to do the entire car.
Recently purchased a California duster and it seems to do a decent job but old habits are hard to break and still find myself reaching for the detailing spray and microfiber cloth.
They are definitely not safe for anything more than a dusting of pollen, and I still go over the car with detail spray/microfiber cloth after I use it.
I really only use them for pollen season and that's it. And I would suggest getting a microfiber style duster and not the California brand, because those are made with wax embedded fibers, which tend to keep the dust. The microfiber dusters release the dust when you shake them out.
Been using the California Duster since 2004. Never a problem with scratches or swirl marks. The trick is very little pressure.
Been using the California Duster for 5+ years no problems as long as you use it lightly and the dust is just that a light coat of dust.
Been using the California Duster for about 15 years on light dust that gets on my cleans cars while sitting in the garage with no problems. The trick is to just run it very lightly over the finish. There should be no pressure at all. I just let the ends of the strands touch the finish. The dust is pulled up in to the duster.
Don't use the duster in place of a car wash though. If the car is dirty it needs to be cleaned, not dusted.
Received 4,557 Likes
2016 C2 of Year
2015 C3 of Year Finalist
I have also been using the California car duster for many years with no issues at all. As long as the car isn't dirty and it's minor dust I think they are fine. I think it's nonsense to wash a car that is clean. I use the duster and then a spray detailer with a good microfiber.
Former Vendor
http://www.autogeek.net/ultima-water...ncentrate.html
I prefer to use Ultima's Waterless Wash and several super thick and super soft MF towels. The nap of the towel pulls any dirt up and away from the surface, and the lubrication helps to loosen anything stuck on paint.
Former Vendor
I use the California Duster. Question I have about Ultima's is you wipe the the dust harder than you would be with a California Duster or am I missing something. It seems that the duster is more effective at remove dust without creating scratches from the dust than hand wiping.
A soft MF towel has more of an ability to pull these contaminents up and away from the surface. Flipping the towel again and again also exposes a fresh surface. Ultima acts like a lubricant to help the towel slide across the finish and its ingredients help to break up dirt and loosen it also.
Race Director<br><img src="/forums/images/ranks/7k-10k.gif" border="0">
St. Jude Donor '13-'14-'15-'16-'17-'18-'19-'20-'21-'22-'23-'24
I also have been using a California duster for many years with no problems at all, but as stated above use it correctly. If it just a dusting between washes I blow the car down first with a commercial HVLP turbine which is basically a master blaster. We happen to have them for work. Then very lightly with the tips of the duster only wipe the dust off very lightly, and shake it out good after every panel. I have never scratched a car yet using this method, but I scratched my wife's new Lexus trying the ultima waterless wash+. I thought I did everything correctly and ended up having to buff out the roof and trunk lid on her new White Lexus. I do like the waterless wash as a QD, but I personally will never try washing a car again in that fashion. The car wasn't even that dirty.
Former Vendor
** one hint, use it as a spray to loosen dirt and start the process, then make two buckets of water one for rinse and the other with Ultima. (consider Grit Gards)
