Cleaning Grey Painted GS Wheel Barrels
What is a recommended product for cleaning brake dust and road crud from the grey painted inside wheel barrels of chrome GS wheels? I plan to remove the wheels.
BIGMAC
BIGMAC
Former Vendor
You should consider using a detail brush when cleaning wheels to keep dirt off the barrels as possible, or to a minimum.
http://www.autogeek.net/ezdebrfca.html
When removing the wheels you can clean them with your wheel cleaner first. Then consider using a paint cleansing lotion and even a paint polish as needed. I have heard some using Tar Removers and even Wd40. Just remember to test in small areas and never clean them while hot.
To make future cleanup easy, and likely to avoid having to remove wheels. Consider coating the wheel barrels which makes a long term notable difference.
http://www.autogeek.net/gtechniq-c5-wheel-armor.html
Former Vendor
Our Deep Wheel Cleaner does a killer job on brake dust. Make sure you follow the instructions and spray the DWC on a cool dry wheel.
Check out the video!
http://adamspolishes.com/video?video_id=5
