Anyone know if/where I can pick up a set of 'Corvette Racing' floor jack crossbars that will fit under a 2016 Z06 w/Z07 perf. package? Yes, I know you can use wood and there are plenty of DIY types of crossbars out there. Thanks in advance.
I saw that one but I believe even at its most closed setting it's still too wide for the back of the car. But I'm still specifically looking for the one's from Corvette Racing if they can be had. Thanks.
There's a guy on fleabay that has them. Front and rear different width's. They look powder coated with Corvette Racing stickers. Not cheap though.
Those are the ones! You're right; not cheap if you want them powder coated to match your car color and another $20 for the Corvette Racing stickers. But they are the correct size for the car which is important to me. The other thing is that he makes the pin whatever size you need for your floor jack pad. Might be a good idea to make it 1/8" smaller than it needs to be.
