Wax Only
Wax Only
Looking for a wax that will really give some pop to arctic white exterior on the C7 Vette.
Not interested in coatings or sealants, any suggestions or good experiences would be appreciated.
This of course assumes the paint surface is properly prepared, wash, clay polished, etc.
Grand Poobah
This stuff is old school cool and just about the wettest wax I've tried.
dvilin (03-27-2016)
Pro Mechanic
Received 3,952 Likes
Adam's Patriot Wax, if going to show the car, top that off with Adam's Brilliant Glaze just beforehand.
The following 2 users liked this post by rkj427:
Adam's Polish (03-26-2016),
dvilin (03-27-2016)
Former Vendor
Thanks rkj4243 for the kind words!
http://adamspolishes.com/shop/exteri...triot-wax.html
http://adamspolishes.com/shop/exteri...aste-wax4.html
Adam's Polishes is the Officially Licensed Car Care Product of Corvette & Camaro.
dvilin (03-27-2016)
Former Vendor
Pinnacle Liquid Souveran is my choice when using a wax on white. It has no cleaners and no polishes. It is a pure wax using carnauba as a base. It does have some other synthetic ingredients but not a sealant or coating. It is very easy to apply and even easier to use. Thin, light coat is best. Heavier application is not longer or better protection, it simply wasted product. Pinnacle also offers Souveran Spray Wax as a booster.
dvilin (03-27-2016)
Liquid souveran
PB liquid blue
PB liquid red
PB liquid blue
PB liquid red
dvilin (03-28-2016)
dvilin (03-28-2016)
Scuba Ghost (04-06-2016)
http://www.autogeek.net/collinite-in...r-wax-845.html
And here is an excellent write-up on Collinite 845. Amazing stuff and sooooo easy to use. They aren't kidding when they say "thin, thin, thin"!
http://www.autogeekonline.net/forum/...ndary-wax.html
-Mickey
dvilin (04-04-2016)
dvilin (04-04-2016)
St. Jude Donor '18-‘19-'20-'21-'22-'23-'24
I have also used wax over Rejex for a bit more pop. I guess in my case just looking for something different in the wax line of products.
dvilin (04-06-2016)
Received 2,682 Likes
2018 C5 of Year Finalist
I have used a sealant in the past (rejex) and it did a nice job. Last a bit longer than wax, but I feel that wax gives a deeper shine and I do not mind the reduced time effectiveness of wax.
Former Vendor
Generally:
1. Traditional 'Nuba Waxes -- depth, wetness, use oils to make paint look richer ...also offered in spray wax versions
2. Sealants (synthetic waxes) --- offer more durability, in the past they look sterile or plastic-like. They mimic wetness using gloss. Newer sealants appear to reflect better. ... also offered in spray version.
3. Coatings --- Offer the longest protection in a single application. Often glossier than any other offering. Extremely reflective. Buffing off the product is limited to high spots (over application). Product doesn't need a booster or topping, unless desired for looks.
dvilin (04-06-2016)
I get good results from wax and sealant so for me it's a case of temperature.
The Collinite #845 (carnauba) label states:Surface should be lukewarm to the touch.
The Wolfgang Paint Sealand label states:Surface should be cool to the touch.
So, warmer months=wax, cooler months=sealant.
-Mickey
-Mickey
Former Vendor
Collinite Waxes are some of the most durable offered. They often meet the durability of a good sealant. Infact, sometimes it will surpass them. (its rather interesting to study their product and original design and uses)
Seasonally I would counter and suggest most would use a sealant during the hot summer months, and a wax during the cooler months. Why ?? Because sealants have a higher heat point meaning they don't wear as quickly in the summer sun/heat.
To expand on the labels , and mostly using my personal experience, a wax/sealant/coating will work best on a cool surface outside of direct sunlight. Now certainly many other variables exist like humidity. But most products are tested in controlled environments and the manufacturers directions are based upon that outcome. It certainly is "cool" (pun) to find out your product works in direct sunlight also, and thus you could advertise it to stand out against its peers. Also some formulas, like Collinite, are thicker and the lukewarm suggestion likely helps it dry quicker and perhaps even spread a bit easier. --
-Mickey
Former Vendor
This product is often missed and superior to even some liquid and paste waxes. It offers a true UV protectant in it and super easy to apply. Amazing looks and beading too.
http://www.autogeek.net/optimum-spray-wax.html
