Car Care Discussion Car Detailing Info, Wax, Wheel Polish, Interior Cleaning Tips for the Corvette
Pad recommendations ?
Old Jun 3, 2016 | 09:06 AM
CheckeredFlag's Avatar
CheckeredFlag
Default Pad recommendations ?
I'm planning on trying some Klasse All in One on my Wife's daily driver, and I could use some new pads for my Porter Cable 7424 XP
Suggestions ?
Old Jun 3, 2016 | 09:28 AM
JimmyS5600's Avatar
JimmyS5600
Active Streak: 90 Days
I use Lake County 5.5 pads in either white or yellow. Yellow is more
for "buffing" but either would work well. Iam sure others will
chime in.
Old Jun 3, 2016 | 11:01 AM
yamabob's Avatar
yamabob
I myself prefer the Lake Country 5.5 flat pad over the Hydrotech and CCS pads of theirs. Really comes down to ones own taste to me.The pads have their own "abrasiveness" to them. Yellow and Orange are the most aggressive with yellow being the most. usually for heavy marring/correction work. Then white-black- blue-gold. You can change up pads for different effects. I more than likely start with the white pad.
Check out Autogeek as there is a new line of pads out which I will soon venture to try.
Old Jun 3, 2016 | 03:59 PM
Killrwheels@Autogeek's Avatar
0Killrwheels@Autogeek
Former Vendor
I like LC hydro tech pads for many reasons, but one of the most obvious is that there are only 3 abrasive levels. Simple and effective for almost all polishing.
Now that said, please realize Klasse AIO is a chemical based paint cleaner with some protection benefits. It has no real polishing abrasives in it. So using the wrong pad might actually harm paint and cause some light marring . I would use a non abrasive pad with this product specifically.
If you are also using Klasse SG (silver bottle, pure sealant) there is a trick to getting awesome results without it being challenging. Put a ounce or two in a small travel size hairspray bottle. Spritz it on, then immediately buff off via MF towel. After a couple hours it will still fully cure to a rock hard appearance.
Old Jun 3, 2016 | 10:20 PM
CheckeredFlag
thanks !
Old Jun 4, 2016 | 09:21 PM
Broker99's Avatar
Broker99
With cleaner based sealant i have had good results with finishing microfiber pads.
Old Jun 5, 2016 | 07:33 PM
JoeD-C8's Avatar
JoeD-C8
St. Jude Donor '18 thru '25
I like the Meguiars pads, they have a finishing one with light cutting that would work out well with an AIO product.
If you were going to use a compound then a polish I still like the Meguiars cutting or extra cutting pads and then go to finishing pads.
To Pad recommendations ?
