Car Care Discussion Car Detailing Info, Wax, Wheel Polish, Interior Cleaning Tips for the Corvette
inside windsheild cleaning
Old Sep 21, 2002 | 05:44 PM
blu93conv's Avatar
blu93conv
Default inside windsheild cleaning
Does any one have a good way to get the inside of the winshield clean. it is soooo hard to get to . it seems that no matter what i try, as soon as the sun shine on the window I see streaks.
Old Sep 21, 2002 | 06:54 PM
AZGASSER's Avatar
AZGASSER
Default Re: inside windsheild cleaning (blu93conv)
I use Stoner's Invisible glass, available at AutoZone. I clean only with crumpled newspaper and this seems to work fairly well. Good luck! :seeya
Old Sep 21, 2002 | 07:37 PM
DsC5's Avatar
DsC5
Default Re: inside windsheild cleaning (AZGASSER)
this is the best I have found so far, but still not good enough. Hoping somebody has some suggestions too. I have heard just water and a towel will do the trick. I'm going to try it, but I don't think so. :seeya
Old Sep 21, 2002 | 11:12 PM
Joe S's Avatar
Joe S
Yes, I finally found one that works very well. It is called Glass Wax. You can find in local hardware stores.
Glass Wax is an old product. It cleans the windows the first time. Streak free. Believe me I used everything.
If you don't want to use Glass Wax, try applying any other glass cleaner, windex or stoners etc. Let it dry, then
polish window with a good dry cloth. You must apply alot of elbow grease. If front inside window has alot of haze,
two cleaning will be necessary. Remember, the more dressing you use on the dash, the more haze you
will have especially in the Summer. Good luck.
Joe
Old Sep 22, 2002 | 02:17 AM
stenoslave's Avatar
stenoslave
Default Re: inside windsheild cleaning (Joe S)
Here's another vote for Glass Wax. Leaves the windows streak-free and sparkling when wiped off with a microfiber towel. A little goes a long way. But be careful, tends to stain black plastic and doesn't smell all that great (but it does bring back memories when my mother used it when I was a kid back in the Fifties).
[Modified by stenoslave, 10:19 PM 9/21/2002]
Old Sep 22, 2002 | 10:43 AM
rubyred93's Avatar
rubyred93
Default Re: inside windsheild cleaning (stenoslave)
That Glass Wax sounds interesting. I've never heard of it before, but I'm goind to poke around the hardware store the next time I'm there and see if they carry it.
I have used Stoner's Invisible Glass in the past, and it is okay, but have found SprayWay Glass Cleaner to be more effective. I like to use the SprayWay combined with a quality microfiber towel...works very well.
:yesnod:
Old Sep 23, 2002 | 01:03 AM
AZGASSER's Avatar
AZGASSER
Default Re: inside windsheild cleaning (rubyred93)
I posted yesterday about stoner's, well after going on an evening cruise with the wife, she noted how many streaks there were on my windows and said she would clean them in the morning. She used glass wax and man they are damn near invisible now. I hate to admit it but she helped keep my ride looking tip top, now if I could only convincer her to polish the car I would be set! :seeya
Old Sep 23, 2002 | 10:27 AM
Silver2002's Avatar
Silver2002
Cruise-In III Veteran
St. Jude Contributor
I have few if any streaks on my windows and this is how I clean them. I spray Invisible Glass on a paper towel and wipe down the window. I immediatly follow up with a dry paper towel. After a few moments I will take a dry 100% cotton towel and wipe down the entire inside of the window. The most important part is that I do this in the garage where the glass can remain cool. It is almost impossible to get glass streak free when the glass is hot from the sun or other means.
Old Sep 23, 2002 | 11:46 AM
Joe S's Avatar
Joe S
Here is where you can buy on line:
doityourself.com/store/windowcleaners.htm
If you need more info, just let me know. As I stated before, the stuff cleans the haze off like no other product.
The added plus is, it is so easy to use. Good luck,
Joe
Old Sep 23, 2002 | 11:49 AM
stenoslave's Avatar
stenoslave
I found it at my local Ace Hardware for $4.99. Thanks for the web link.
To inside windsheild cleaning
