Freshly Waxed Shine
Freshly Waxed Shine
Immediately after waxing black cars, I find that proverbial wet look shine is there.
That shine seems to disappear 24 hours later, no mater which product brand.
Okay... is it just me?
Everything shows up on black. It's kind of a losing battle, but dust is first to show and God forbid you get caught in the rain. At least if you have the right Sealant / Wax combo, the clean up should be easier.
Maybe give it boost with a good detail spray..
Yes Zaino works great but which product? I think you mean their sealant.
OP- I think what you're looking for is what combination of product will help to keep your black car looking clean and shinny between proper wash cycles.
From a conventional way, I always found that after a proper paint correction was completed to use Sealant, let it cure then a good carnuba wax over that. It proved good protection and made the next several washes much easier.
Ceramic coatings are also an option and once I get more than a few hours in my schedule, I'll be applying the Adams system to my C7. I'll certainly document the process and share my results.
In the mean time I'll see if I can find a shot of my black Camaro and what it looked like using the conventional method mentioned above and post.
Thanks for the replies.
I'll try to clarify...car is corrected, polished and carnauba (not a cleaner wax) wax applied.
(Disclaimer...we all know black painted/ waxed cars look good for about 10 minutes.. until the dust settles)
What I am asking/ stating is that after a fresh wax the car has the "wet look."
24 hours later that "wet look" is gone and detail spray does not seem to return that wet look.
Is it just me...are the chemicals in the wax evaporating away?
What will return the "wet look" is adding additional carnauba wax (or a glaze).
Again maybe it is just me and/or the nature of carnauba.
For fun I prefer the natural waxes over synthetic or sealers.
Thanks for all the replies.
I usually use a sealant then Wax. For me the sealant offers that extra kick of wet, plus it changes the hydrophobic properties of the surface once it cures. Then the wax goes on top of that creating a pretty hard base. Then.....
If the dust is light enough I'll either just blow it off and reapply some detail spray or if it's heavier but not sticking, I'll use my California Duster (there is a proper way to use it) to remove the dust then hit it with detail spray.
Yes admittedly I'm a Adams fan and especially their Detail spray. That seems to me to really bring back the wet look you're describing, but only providing the recommended application of sealant and then wax is applied first.
I have used a combination of Zaino's sealant and Adams Americana before with really good lasting results.
But I do get the frustration with sold black and even with all my detail tricks, I was glad to get rid of my Camaro C5 vert and get a gray C7 wth some metal flake in the paint.
Ran across this video from Larry at Ammo and thought of our discussion. His product Ammo is a boutique brand, but take product out of the equation and listen to what he's saying about when to wash it and when to use a technique like the one he's recommending. Obviously there's a point, but it's rather subjective for everyone. As long as you're happy with the results, that's what matters.
A few guys in the Camaro forum have used his products and his techniques are somewhat different than the conventional processes, but it's another resource I use to compare and contrast my own techniques against in search for that perfect shine, particularly in between details.
Hope it helps.
Hope it helps.
Interesting. I don't agree about the water blade--if a quality one, potentially harming the paint. It is pushing water, not spreading it like the mf towel. Anything it pushes is well lubricated by the water. But my question is: what does he mean by "hydrate"? What product is he using? I've never heard of a specific product to hydrate the paint, other than it being included in waxes/sealants.
Former Vendor
If you apply a quick coat of Glaze it will make your paint pop.
And the great thing about glaze is it will not build up like wax will.
http://adamspolishes.com/shop/exteri...ant-glaze.html
I agree about the glaze, it will give you a wet look. IMHO the best glaze is no longer made,
Danase Wet Glaze 2.0. Nothing today comes close. A few good ones but most are overpriced and over rated.
corvetteflier (08-26-2017)
St. Jude Donor '09
Black really isn't a color, its a full time second job....
After two black daily drivers, I tapped out and have bought tan and white vehicles. Life is good again.....
And so much easier.....
