Should I do something to protect new wheels?
Normally, I would just wash/wax new wheels. Is there any benefit to applying some of the new coatings? Should it be done before or after getting tires installed and balanced? I'm not sure if the coating would interfere with the sticky weights.
Supporting Vendor
We coat after mounting and balancing.
I just applied GYEON Rim to a personal set of wheels yesterday and have 2 coats of Kamikaze Stance on my daily.
The coatings will last longer, have more heat resistance, and be easier to clean for years to come vs. waxing. We highly recommend it and haven't used a wax in the shop for years.
-- Ryan at ESOTERIC
-- Ryan at ESOTERIC
__________________
________________________________________ __________________________
ESOTERIC Fine Auto Finishing - America's Premier Corvette Detailer
Detailing . Paint Protection Film . Protective Coatings . Car Care Product Sales . Training
HRE Wheels . Forgeline Wheels . BBS Wheels . Akrapovic Exhaust . Fabspeed Exhaust . KW Suspension
9801 Karmar Ct. New Albany, Ohio 43054
(614) 855-6855
Contact@esotericdetail.com
EsotericDetail.com
EsotericCarCare.com
ESOTERIC on YouTube
(614) 855-6855
EsotericDetail.com
EsotericCarCare.com
ESOTERIC on YouTube
Received 1,033 Likes
St. Jude Donor '09-'10
Coated all of our wheels and tires, cleanup now involves spraying with a hose, quick wipe and drying. Last wash I used a white microfiber towel to wipe and then dry wheels after hosing down, little to no dirt transferred to towels.
Cleaning wheels and tires used to be a big pain in the azz.. now it's an afterthought and the wheels and tires pretty much always look fresh.
-- Ryan at ESOTERIC
-- Ryan at ESOTERIC
I've never found a product that would allow me to just rinse off a wheel with brake dust to spotless condition without physical agitation....but I haven't used any of these new coatings, either. I would love to find something that would rinse the brake dust off to the point that it would pass a "white glove" test....not sure if that is possible??
What are your thoughts?
Esoteric,
What do you think about my post below....is it possible to have a true rinse off system for brake dust that involves no physical touching of the wheels to get them pristine?
TIA
TIA
Can you detail exactly how much the coatings will help with cleaning of the wheels? I have issues with daily driven Range Rovers that come stock with big Brembos that stop the big heavy trucks nicely but obviously use very soft brake compounds and will dust the rims with a layer of brake dust in one 80 mile round trip (fronts 3 times the dust of the rears). If the Stance coating is applied, will brake dust really just hose off or will physical agitation still be needed to remove the brake dust? Right now the wheels are waxed with an over the counter wax and a pressure washer removes most of the dust but if you wipe with a towel it really shows how much is left.
So for the next question, which of the brands and products you handle do you recommend for the following:
1. Street driven daily driver Range Rover and Ford Super Duty both running stock pads. Would like to do rims on both and the colored calipers on the Range Rover. The rims are stock and appear to be painted (maybe powdercoated) and cleared on both trucks.
2. C5Z06 track car with aftermarket brake rotors and very high performance track pads. I'm thinking these pads are very metallic based compared to stock. Also the heat generated by the brakes and tires really gets the rims and calipers very hot. Is one ceramic type coating better for high heat situations over another? I'd like to coat the yellow AP Racing calipers also if you recommend that the coating can handle the heat. The rims are factory stock C5 Z05 Speedline rims which appear to be painted or powdercoated.
Esoteric Detail (08-02-2017)
Supporting Vendor
The entire kit is on sale: http://www.esotericcarcare.com/gyeon-mohs-pro-kit/
and we literally just dropped an extensive video on it this morning:
TrackAire (08-02-2017)
Any idea on how many wheels/coats the GYEON Mohs rim kit can do? $45 seems like a lot for people that buy over the counter stuff, but if you can do 3 coats on two sets of wheels that may be easier to handle.
Also, on a daily driver that stays parked in the sun during the working hours of the day, what realistic duration can I expect from the coating?
Supporting Vendor
I have to add that how you apply is going to change how much you use per coat. Foam applicators, which are easier to use tend to slather on more, while the included suede cloths tend to lay it on thinner which will get you more coats and is easier to buff off with a microfiber. A little goes a LONG way and the largest mistake we see newcomers make is using way too much.
Duration is of course going to vary on a variety of factors. 2 coats should get you around 2 years. The occasional wash plus a topper of some sort (like GYEON Wetcoat) will help.
-- Ryan at ESOTERIC
St. Jude Donor '18-‘19-'20-'21-'22-'23-'24
All great advice. I know this is rather OCD but remove your wheels and give them a proper washing and then coat the faces AND the barrels. The outcome will be an almost carefree experience!
Esoteric Detail (08-08-2017)
I have used gyeon rim on 5 sets of rims and I am a believer
I have used it on new wheels and wheels that had been driven on and the results where worth it.
I've got a new set of rims on order and they will get gyeon as soon as they arrive.
The wheels have a"wetter" look at clean easier - I also think they retain less brake dust as well.
I also coat my calipers with gyeon rim and find them much easier to clean and keep clean
Esoteric was kind enough to educate me and I've done them all myself.
Just follow the directions and make sure you start with a clean surface
Esoteric Detail (08-18-2017)
