Coolant Leak on Carpet
Hey All,
Brand new to the forums and wasn't sure where to post this. I have a 1967 Corvette and the heater core leaked coolant all over the passenger floorboard. It leaked a lot, maybe 2 gallons. I have fixed the heater core and vacuumed out all the coolant but still have a big problem.
The coolant has left the carpet very greasy. I have tried to use Zep degreaser and a good carpet shampooer twice to suck it out but it still is greasy. So greasy I can't even have anyone ride on that side.
Any ideas on how to fix this is appreciated. I would hate to have to replace the carpet as it is very new and in great shape.
Thanks! Love this forum!
The heater core leaked in my ‘58 and it was not a happy time. I pealed back the carpet and used a towel to soak up as much coolant as I could. Then I used a foaming cleanser called Tuff Stuff about 6-7 times blotting and vacuuming after each application. I’m sure there is still some coolant left in the carpet fibers but the slimy residue seems to be gone.
You may need to remove the carpet and take it to a professional detail shop where they can use professional cleaning equipment and products. Antifreeze has that sweet smell that will remain especially when you turn the heater on this winter. I had a '66 that had a leaking heater core and it took weeks for the smell to finally dissipate.
I just remembered that I also used the garden hose and completely saturated the carpet and blotted and vacuumed as much water out as I could. Did this a couple times and left a fan in the car to keep air circulating. Then I followed up with TuffStuff. The whole process took about a week. Good luck with your situation....coolant is pretty messy stuff.
